1 - 7 of 7 Posts
· Registered
I have a 2009 4.0 caravan. Found a power steering leak from one of the lines on the rack and pinion. Can't find a diagram or parts list to buy the lines separate from the rack and pinion. If anyone could help me, that would be great.
· Premium Member
Welcome to the site.
Those lines are not normally a service part that you can buy.
I've had to repair a few in my day with bulk line and compression fittings.
Normally a repair shop will be selling you a rack if one of theses lines fail/rust out.
· Super Moderator
Thanks. Going to try and replace lines.
Good luck. It's not uncommon for those small steel lines to rust out necessitating a complete rack replacement. Most recent for me was a 2004 Acura TSX last year. Good luck with the fix, I've always thought it should be tried. Tough spot to work though.
· Registered
There's a Company on Ebay that sells the steel lines that fit on the rack. 2008/10 and 2011/18
1 - 7 of 7 Posts
