My solution
The job is done. If it were not for the pulley troubles, I would have been done in a day. It ended up taking me 2 full days.
The rough steps I followed were:
1. Remove the cowl for room.
2. Remove the serpentine belt.
3. Remove the passenger wheel and splash shield.
4. Remove the alternator.
5. Remove the top alternator brace plate.
6. Remove the top 3 bolts from the alternator / power steering mounting bracket AND the one in the back mounted to a stabilizer bar.
7. Remove the bottom 3 bolts from the alternator / power steering mounting bracket. Requires offset 15mm and obstruction 15mm.
8. Remove the 3 bolts (behind the pulley that mount the power steering pump to the alt / ps mounting bracket.
9. Remove the high and low pressure lines from the ps pump.
10. Remove the nut that hold the ps pump from behind.
11. Remove the alt /ps mounting bracket from the engine compartment allowing the ps pump to stay behind. Below is a good shot of the bracket.
http://picasaweb.google.com/dpstickney/Vehicle?authkey=Gv1sRgCI2P9tOL4O6BUw#5482422223344925410
12. Disconnect the filler tube and remove the ps pump.
13. Remove the ps pump pulley (messed up here... no gear pullers!!)
14. Remove the stud and filler bolt from old pump
15. Install stud and filler bolt from old pump
16. Install pulley (troubles here... If buying a new pulley, be certain you have the correct one...)
17. Install filler tube and insert ps pump into cavity from above.
18. Install alt / ps pump mounting bracket.
19. Attach ps pump to alt / ps pump mounting bracket. This is a pain...
20. Attach high and low pressure lines
21. Install alternator.
22. Install cowl.
23. Install splash shield and passenger wheel.
24. Add fluid and bleed.
Note: I did attempt to install the ps pump attached to the alt / ps mounting bracket to save myself some trouble, but the stabilizer bar behind the alternator seemed to block my path. Below are some pictures of this failed attempt.
:Wow1:
http://picasaweb.google.com/dpstickney/Vehicle?authkey=Gv1sRgCI2P9tOL4O6BUw#5482422249654928738
http://picasaweb.google.com/dpstickney/Vehicle?authkey=Gv1sRgCI2P9tOL4O6BUw#5482422290930338722
Good times! Let me know if you have any questions. Thanks! :thumb:
Dave
