1 - 5 of 5 Posts
The RAZ radio in my 2006 Grand Caravan no longer produces sound. The radio comes on, allows me to change channels, etc, but no sound comes out. Any ideas:
check fuses? does it have infinity amp? (if so, check "name brand speaker" relay)
I hate to say this because I always do but pull the IOD fuse or neg battery cable for a minute and then see if it works. I can't tell you how many times a "reset" of certain modules solves most of the problems with this cars. This is most likely assuming you have the amp.
Discussion Starter · #4 ·
Which fuse do I check
I plan to check the fuses as recommended. However, I want to make sure I do not cause a problem with an important fuse.
The instructions refer to a "30 Amp Pink" fuse in cavity "F20" with a description of "Central Amplifier". Is that the right fuse?
Discussion Starter · #5 ·
Thanks for the responses. I ended up trying both suggestions above but no luck.
I had a mechanic check the fuse and he told me it was ok.
I unhooked my car battery (in fact I ended up replacing it) and it made no difference.
1 - 5 of 5 Posts
