Do we have a button combination on the fobik that would allow us to lower the windows remotely?
So you have to pick between the beefy engine and updated body styling or a neat fob feature. Lame. Anyone tried to adapt this feature to newer ones?MY08-10
I mean the 4.0L is a far beefier engine option than the 3.6L.So you have to pick between the beefy engine and updated body styling or a neat fob feature. Lame. Anyone tried to adapt this feature to newer ones?
Much like the powered tailgate, which can be opened and closed manually I wish that the side doors did the same thing.The more the windows are going up and down, sometimes needlessly, the more wear and tear on the components, which are known to be fragile to begin with. Just another electronic nicety to deal with.
Power sliding doors is another one. Great but the lock actuators are prone to failure (there's an extended warranty on some of those).
I am going to go dig and see. Just need some time.Wonder if we can re enable with FCAdiag.
They can be opened and closed manually too, press the power function disable button on the overhead console and your power doors will turn into fully manual doors except the key buttons and the overhead console door buttons.Much like the powered tailgate, which can be opened and closed manually I wish that the side doors did the same thing.
As for the Windows that's simply a software setting so I think they must have disabled the function.
Auto window works on my 2011The remote window feature can be used by pressing the unlock button once and then pressing and holding it a second time. Within 3 seconds both front windows will roll down together, the windows will roll down until you release the unlock button to which the window will then stop at whatever position you release the button at. Only works 2008-2010 model years as steffen stated above.
Works on my 2011 T&C Limited also; never knew that. So - is there a similar button press sequence to raise them?Auto window works on my 2011
