Removing the bottom glove box on a 2016 Town and Country
6.1K views 4 replies 3 participants last post by  Jeepman
#1 ·
Is there a Chrysler Town and Country 2016 owner that has removed the bottom glove box ? I got a pill bottle stuck in the back of the glove box that stops it from closing.
#2 ·
From the Owner Manual, Page 633, or there abouts, for the A/C Air Filter
The A/C air filter is located in the fresh air inlet behind the glove compartment. Perform the following procedure to replace the filter:
1. Open the glove compartment and remove all contents.
2. Push in on the sides of the glove compartment and lower the door.
3. Pivot the glove compartment downward.
4. Disengage the two retaining tabs that secure the filter cover to the HVAC housing, and remove the cover.
5. Remove the A/C air filter by pulling it straight out of the housing.
6. Install the A/C air filter with the arrow on the filter pointing toward the floor. When installing the filter cover, make sure the retaining tabs fully engage the cover.
CAUTION!
The A/C air filter is identified with an arrow to
indicate airflow direction through the filter. Failure
to properly install the filter will result in the need to
replace it more often.
7. Rotate the glove compartment door back into position.
