1 - 2 of 2 Posts
Hello All and Thanks Very Much in Advance for Your Help!
I pulled an ECM from a '97 / '98 2.4L , for my '96 2.4L.
My questions, are:
1) Are different years / part numbers interchangable?
Old P/N: P04727149 / 0472 / 7149 Black Connectors
New P/N: P04727151AH / 0472 / 7151AH Grey Connectors
2) Regarding anti-theft: Mine, does not have it; don;t recall if the other did or not
3) If required, where can I get it programmed, cheaply?!
I am also buying the BCM and TCM!
Thanks Again for Your Help!
You can't replace non anti-theft BCM or PCM modules with ones that have the anti-theft feature. Nothing but trouble if you do. I would check with the dealer parts people about interchangability. Best to use matching part numbers because of software changes. Just my $0.02.
FredB
1 - 2 of 2 Posts
