1 - 8 of 8 Posts
Administrator
I did a quick search and could not find anything. Everything I found was for the 2008 to 2020. Any help
As far as I know, none of the 4th generation vans have an oil change light to reset.
2008-2020 is the 5th gen van. Before that, there was no change oil light/reminder.
No oil change message in my 2004 Limited with evic. It's a 5th gen thing.
Reactions: Carbuff2
I think the vans with EVIC have an oil change reminder, could just be certain years. But I don't know that it actually shows a light, it may just be a message on the overhead display.
EVIC has a service interval reminder which displays "PERFORM SERVICE" when it reaches set mileage - there is no "oil change light" (only above mentioned oil pressure light, which is usually set off by faulty pressure sender unit)
1 - 8 of 8 Posts
