I apologize if the info is posted. I searched extensively here and the web in general.
2001 T&C Limited with Infinity sound + 4-disc changer. I think this means 8 speakers: 2 in each of the four corners. Correct?
Previous owner had an aftermarket head-unit installed. I hate this unit and it doesn't control the disc changer.
So, I found a new factory radio for $40 and bought it. I'm trying to install it and return the van to factory conditions ... and have questions.
1) All of the harnesses behind the dash are intact, which is good. With one possible exception. There is a thin white connector that contains one wire: white with purple stripe. The thin white connector has a spot for another wire, but it's empty. There is another wire that looks like it should go into the thin white connector and it's grey with green stripe. This wire is otherwise unconnected to the radio. Should it go back into the thin white connector?
I can connect the new factory head unit and it "works." Locks onto stations, illuminates, etc. This is without the grey/green stripe wire connected to anything. Does this make sense?
However, no sound anywhere. I assumed that this was because the speakers were spliced to work with the aftermarket head unit and the factory harnesses no longer make a connection to the speakers. Correct?
2) The factory 4-disc changer had nothing connected to it. It was sitting there as a space holder. No cable. What cable do I need to connect it to my factory head unit?
3) Pulled off the panel to one of the rear speakers and found some sort of harness that's not connected to anything. Two wires had been cut and spliced to normal speaker wire and run up to the aftermarket head-unit. This is the big one. What is supposed to connect to this harness? How do I reconnect the speakers into the factory head unit? Will I find the same thing when I remove the door panels and look at the front speakers?
4) the speaker itself was just a lone speaker. Two "spades" that allowed pos/neg wires to slide on. On the opposite side was what looked like a mounting plate, with two screw holes, but nothing actually mounted there. Should something go there? Is my speaker(s) missing something?
Thanks for your help.
