1 - 5 of 5 Posts
My ongoing electrical saga here: http://forum.chryslerminivan.net/showthread.php/61370-Is-my-failed-instrument-cluster-likely-its-soldier-joints-or-the-BCM
Currently, I'm at an estimate of $750 for a remanufactured BCM, probably not including labor.
The mechanic working on it said he'd look for a used one, but hasn't called back.
This eBay service is offering to rebuild mine for $140: http://www.ebay.com/itm/95-00-Dodge-Caravan-Body-Control-Module-BCM-REPAIR-RETURN-SERVICE-/221552656789?pt=Motors_Car_Truck_Parts_Accessories&hash=item3395914195&vxp=mtr
Since it's mine, that means no reprogramming! Yea!
Could anyone recommend trying this or not?
Thanks!
Did you get it fixed? If you did How it is working? Thanks!
Still working on it - a little less than 3 hours Saturday removing the bcm (being careful as a non-mechanic). I'll post an update either way when I re-install it.
If everything is good it should work right away I think. I'm interested in knowing how good SIA is, I have to get a PCM and I'm leaning towards SOLO (also in EBAY) but your experience might get me to re-think about it.
1 - 5 of 5 Posts
