1 - 3 of 3 Posts
02 Chrysler Town and Country 3.8L V6, 155,000 miles. Hi everyone, Durant happen all the time seems like mostly when can first starts out for the day. But I'm getting a slight slip between 1st and 2nd gear. All the rest of the gears shift smoothly. Also, sometimes when I start to go up a bill it's almost like it slips our of low gear for a second and then proceeds normally. It's actually been doing all of the above described for a couple of years with no major problems as of yet. I'm wondering if a simple transmission fluid and filter change might help. Don't want to flush it just drop the pan and change filter and fluid.
Drivin' Maniac
A slight slip (or, some would say, a 'dithering' clunky shift) between 1 & 2 at light throttle is a common malady on our vans.
If you can train yourself to press the accelerator a little harder until second gear is achieved, you can negate the issue under most circumstances.
Dropping the pan and replacing the fluid can lessen the symptom for a while. Has the ATF been replaced before (that you know of)?
BUT, so can changing the spark plugs! I found that out by accident. On our van, the shifts are smooth with a cold engine (or when shifting with our car's Autostick) I believe that the issue is a ECU programming glitch (too lean during the shift?). I've never investigated a 'fix' for that, however.
BTW, I also use a hand pump to replace a couple quarts of ATF+4 every other oil change, with filter changes ~ every 60K miles.
1 - 3 of 3 Posts
