1 - 1 of 1 Posts
I have a recurring problem with my 96 Town & Country. The bushings that secure the front sway bar to the body of the van seem to wear out quickly (less than a year). I have replaced them with the OEM black ones, Blue ones from Napa (NCP2652335) and the red ones. I can't remember what the rubber was called for the "better" Napa ones but it's supposed to be tougher than the OEM. They are tight putting them on and the van rides quietly for several months and then you start hearing the thumping of the sway bar when one wheel hits a bump for example. Checking uner the van you can feel the play where the bushings have egged out again and the sway bar has slop. I have changed the end links too last time but the old ones were not loose or sloppy. Any Ideas?? Never had a vehicle go through sway bar bushings like this. -Mike
1 - 1 of 1 Posts
