1 - 2 of 2 Posts
So, I'm looking for ideas on where to mount my full size spare to clean up the back of the van.
The donut is going to go back underneath next time I rack the van at work (yes, I'm lazy).
What are you guys doing with full size spares?
I was kinda thinking grabbing a cheap roof rack, and throwing it up there. But I live in Texas. So that tire will probably turn to some nasty jerky pretty quick. Even if I cover it.
Was also considering the swinging style carrier like the jeeps use or the bigger vans.
I don't really want to dedicate to a hitch mounted one, as I do occasionally pull a trailer.
All this is to make room to install a tool box in the back. Which leads to my next thing. Has anyone mounted a smaller tool box in the back? I'll more than likely be ripping the carpet out and doing the wire hider cover things that you can get at home Depot.
I regularly haul engines, trans, misc car parts. So a mobile work area would be dope. I don't mind ditching the second row seating since I can keep the third row stored in the floor. Or I guess I can get captains chairs for the rear. But I rarely have passengers so that doesn't even matter.
Anyway, enough rambling. Oh, this is a 4th gen. I'm open to all ideas
You're probably going to have to reinforce the floor then, as stow N go covers are just plastic. My van is the last of the long wheelbase vans to not have stow n go (2004). I've hauled transmissions, engines and my fold-up engine hoist in the rear. I put down mats and big cardboard to slide the stuff in, and load the engines in the passenger side sliding door and put on an old tire. Then I use ratchet straps on the rear upper seatbelt anchors to tie it in so it won't tip over. My van seats are removable, so I can also use those anchor points for tying things down. I even fit my full size spare tire inside the rear. I leave my seats at home.
If you check out Long_Voyager94's van/build thread, you'll see his custom-made spare tire carrier that swings down to open the rear liftgate. It is mounted on the rear receiver hitch FRAME, so still able to pull a trailer. Just wouldn't be able to use the power liftgate to open with the spare locked in the upright position.
Reactions: Sienile
1 - 2 of 2 Posts
