1 - 9 of 9 Posts
2000 Grand Caravan SE 3.3 L . Got into deep water Thursday in torrential rainstorm. Stalled it. Now it won't start, just one loud click from starter. tapped starter with hammer, no change.
Replaced starter, switched starter relay with one i knew to be working -(horn relay)
now the starter clicks multiple times when switched to 'start ' , but no cranking.
What should I check next? Thanks.
If it is clicking multiple times, it is either a weak battery or bad connection. Recheck the battery (put on charger or jump) and check battery connections. Its one of these.
Has the engine run at all since it stalled on Thursday? (i.e., did you re-start it Thursday and drive it home, and only now it's dead?) If it inhaled water, the engine could be water-locked.
- G
Pull the spark plugs and see if it cranks. Or pull the dipstick and see if there is water on the stick.
Tried jump, no change. Click, no crank.
Thank you for replying.
Discussion Starter #6 (Edited)
Waterlock
No.
Had it towed home.
Havent heard of waterlock. I'll pull front plugs and try that.
Thank you.
Found this article on waterlock...
Ill look at air filter and see if it shows water damage.
http://www.croberts.com/Hydrostatic-lock.htm
IF its been hydrolocked, all is not lost. Unless the engine was at a higher than idle rpm, I can walk you through getting it going again.
My dads boat sank a couple years ago, and I had both engines running again with about 6 hours of work.
Latent car nut
I've seen a number of hydrolocked engines, and the only one which avoided a complete rebuild or replacement "locked" at just above idle.
How deap was this water?
1 - 9 of 9 Posts
