2002 Dodge Grand caravan 3.3 179.XXX miles
I previously posted about this van stalling during long drives. On that thread it was mentioned to replace the crankshaft position sensor. To which I have done. I used an aftermarket one from Autozone and there has been no change. I have not took the van on any long drives but I'm sure it will do the same thing.
Each time the van is driven extensively during hot weather; the engine will sputter and shake (like its running out of gas) and then stall out. But here is the kicker - the van will restart and sputter back out then stall. After 2-3 attempts to restart the van will crank BUT NOT START. after allowing the van to cooler for 45 minutes to an hour the van will RESTART AND DRIVE PERFECTLY.
There is no CEL and no stored codes at this time.
I have replaced the following over the last two years:
Fuel pump and filter (Delphi fuel pump)
Map sensor
Battery terminals
IAC valve
Coil pack
Fuel Injector wiring harness
Plugs and wires
Intake manifold gasket
Repaired all leaks in the EVAP system
Crank position sensor
Here is what I know:
-The van only stalls when the brakes are applied (like coming to a red light or stop sign).
-The van temp DOES NOT GO UP when it stalls. It is normal operating temperature.
-There is no EGR on this van it has the delete plate on the intake but there is a wiring connector where one would go.
-The van runs perfectly fine and has plenty of power l before the stalling. (Which leads me to believe it is not the fuel pump.)
-Only occurs during HOT weather when the AC is running and the engine has been running for extensive amounts of time.
-After stalling the van will start and then die again. This will continue 2-3 times and then the van will ONLY CRANK and not start.
-After 45 minutes to an hour, once the engine has cooled it will restart and drive perfectly. Like nothing is wrong.
-No CEL no stored codes
I have not replaced the camshaft position sensor, but its next on the list. Becuase the problem is intermittent I'm not inclined to take it anywhere because I'm 100% sure I'll get the usual, "We can't find anything wrong with it." I have been working on cars for about 10 years and have plenty on experience but this van is throwing me for a loop. It has also become a safety issue because of the stalling.
Map sensor
Battery terminals
IAC valve
Coil pack
Plugs and wires
