1 - 5 of 5 Posts
If your steering wheel has no audio controls, you have nothing to worry about...
"High Line" vans have SC that feed to BCM and head units are controlled via PCI bus - in all likelihood, aftermarket units are not going to support it
2005 Caravan/ Town & Country
i love the controls on the back of wheel - first thing i missed when i swapped radios
unit has canbus support and dedicated steering wheel wires for audio
is there a wiring harness that breakouts steering wheel controls?
IIRC, someone on here made it work but it was fairly long ago (you might stumble on that thread if you dig long enough)
The control buttons are simple resistance MUX on BCM input.
Problem is, there's no CAN bus on 4th gen, it's VPW on SAE J1850...
1 - 5 of 5 Posts
