So the dash has 5.5" openings on top? I can't remember looking at the holes or the size. The radio puts out 22 watts RMS x 4 and is loud enough for me. Would wiring in new dash speakers change the sound in a bad way? hook them up to front or rear channels?
I love music too!
EDIT--- They seem to have 6.5" speakers or 5.25" speakers as common. Michalb, is your post above a typo or are they just a weird size?
I put a question mark as I was unsure of the actual size, crutch field says the speaker size is 5 1.4 for 2007, I was hoping someone else would chime in.
Each base dash speaker is wired in parallel with the front door speaker, it's not a separate channel unlike the premium amplified system (2004+) which has one amp and each speaker has it's own dedicated channel from the amp. The factory base dash speaker has a bass blocker, so that all the highs and some mids come from the dash speakers and the lows come from the door speakers. The premium system is tuned this way as well.
Here is the low and high version of 2004+ vans, notice the bass blocker on the lower speaker connector.
Below is a factory 2007 base caravan's dash, which has a unused large connector (can't remember what it's for), and a 2 way small white connector. The white connector is for the dash speakers, and you unscrew the plate and install the speaker in place.
When I went through upgrading my base speaker system in my 2009 GCV, (it was the 4 speaker system but all vans are pre-wired for 6 speakers), I swapped the base door 6x9's on their own (to the OEM infinity 6x9's), and then later added the 2 corner dash speakers (also the OEM Infinity 3.5's) with no crossover or bass blocker. The sound was better in my opinion but sounded a bit muddy from the dash speakers, since it got all the frequencies it couldn't play the highs clearly which is why I say it sounded muddy so I cut the wires and added a 2 way crossover, sending lows and low mids to the 6x9's and upper mids and highs to the dash speaker.
Some people on here went the bass blocker route, which would be some kind of a bi-polar capacitor to the positive wire for the smaller speaker, that way less wires are cut. I wanted the best, and I also wanted the OEM subwoofer in our 5'th gen vans so I ended up actually running wires for the factory amplifier, and swapped out all the factory speakers to aftermarket Infinity Reference series speaker, except the sub which will get upgraded in the future.
