1 - 3 of 3 Posts
Hello,
I need a wiring diagram for '97 Voyager tail lights. Just put in LED bulbs, need to add an equalizer to fix hyper flashing, or, if anyone knows which wire(s) are for the turn signals, please comment.
Thanks,
Chase
can't seem to find a diagram for yours on the site i used for mine
your wiring may be different due to the years, but on my 2001 the turn signal wire was white with a brown line
you can actually take the plug apart to verify this with a multi-meter
Figured it out today, was very interesting.. On the left side, the signal wire is the Green wire with Red stripe. The right side signal is the Brown wire with Red stripe. Just posting in case anyone else needs to know, hopefully they land here. I determined wire by putting multi meter to female prongs in female plug connector. The tail light voltage bounces around significantly, everything else is either relatively constant or zero.
1 - 3 of 3 Posts
