I have 2000 Town and Country Lxi , 3.8 engine with 195,000 miles. I am second owner and it had 140,000 when I bought it for $3,400 about ten years ago.
About four months ago, I had the fuel pump replaced in a shoestring auto repair shop. The same day I had the battery replaced at Walmart. The next day, the TC wouldn’t start. I noticed white hard caked build-up around the battery connector so I poured hot water on it. The white build-up somewhat melted away and the TC started and I drove away. I felt so happy.
Then sometimes when I drove the TC, it surged while idling and ran rough. Sometimes it died in traffic but it restarted and I drove on. But most of the time, it drove and felt like a brand new TC. Then sometimes it wouldn’t start at all.
The symptoms were that it would crank easy, start, then die after about two seconds. Then it would start again then die after two seconds. All the accessories such as radio, door locks, horn, lights, wipers, windows, key fob and panic button worked. Then after three starts, it would not even crank but I could hear the fuel pump power up momentarily each time I turned the key. I would try again and again over a few hours but no luck. So I would just leave the TC and drive my Harley (not really that kind of Harley. LOL.)
This dichotomy of running great for a week then not starting at all continued for about four months. I didn’t want to take it to the shop because it was an intermittent electrical problem and we all know how difficult (and costly) those are to diagnose and repair. I felt that the shop might just change a lot of parts because it couldn’t isolate the REAL problem. Lucky for me, the TC always failed in my driveway so I didn’t pay for towing.
Over the four months of problems, I was reading this forum. But it was difficult to hone in on an absolute failure of my TC although it seemed most likely to be ‘solder cracks on back of instrument panel’ because there wasn’t any other better match of symptoms. At one point, I was nearly ready to remove the panel, but the TC started performing like it was brand new so I dropped that idea.
Then one day I drove fifteen miles to the other side of Dallas. The TC ran great for the entire distance. Then after the meeting, the TC started and died three times. Then it wouldn’t crank.
A couple of people tried a few things like jumping the battery, removing and visually checking the IOD fuse, and tinkering. But nothing changed and it wouldn’t even crank. No clacking, no noise except two small clicks of relays engaging and the fuel pump hum. The two friends gave up and left. Then I tried switching around the fuses in the ‘Fuse and relay center’ box under the hood such as IOD with a new fuse. I exchanged the low-beam fuse (after verifying that low beams worked) with the starter fuse and tried to start. Then I exchanged it with the ‘starter fuse’ then the ‘auto shutdown fuse’…..No luck. No start nor even a crank.
I didn’t want to pay for a tow so I decided I would keep trying to start the TC every 30 minutes over the next three hours. Lucky for me I had a book, cold drinks and access to a toilet. So I settled in.
Then I did some heavy thinking about the things I had read on this forum, particularly the ‘hit the dash’ advice. I thought that sounded like an urban legend. Even like a really crazy urban legend. But I thought, I have nothing to lose and it will be getting dark soon. So I headed toward the TC.
I put the key into the ignition with the right hand and wondered where I was supposed to hit the dash. So I turned the key with my right hand and thumped the 'closest to the driver' protruding dash once with my withered left hand. Low and behold…. The TC started and ran beautifully. So I really can’t believe it. But it must be those solder joints on the back of the instrument panel.
So I am going to ask my smart friend to help me remove the panel and solder those joints soon. I will buy solder kit from Amazon ($25.99) because the solder has to be ‘electronic-type’ solder NOT plumbing solder. Thanks to everyone on the forum that has commented regarding the solder cracks on the back of the instrument panel. You have probably saved me more than $1,000 and my sanity.
