141 - 160 of 199 Posts
· 3rd gen > all others
Wow, so much discussion on this. It's pretty simple: the bar is a torsion spring, and some twist in the bushings is to be expected. Ideally the bushings should slip on the bar, or actually be a bearing in a block. By design it can't be, because the bushings also have to hold the bar from moving side-to-side to locate it. So the bushings are trying to allow the bar to pivot inside, but keep it from moving laterally.
It would be nice if some collars could be made to clamp to the bar on each side of the bushings (or just a couple in the center part of the bar, against the inside of each bushing) to keep it centered. Then use blue grease on the bar inside of the rubber bushings to allow the bar to twist inside of them, like a bearing. That would be the perfect design/solution.
· Registered
2002 Chrysler Town & Country Limited AWD 3.8L
With the links off, the bar ends freely move up and down around 6”. It has to to follow the suspension as it works. They could not be designed to be fixed at the bushings. It is not a torsion bar. Think of going over a speed bump perfectly straight at speed…both front struts will move up and down equally at the same time, and both ends of the bar will travel with them, unstressed.
· Drivin' Maniac
2002 Grand Caravan ES 3.8L
I'm in the 'torsion bar' camp of intended design.They SHOULD grip the sway bar tightly (as the control arm bushings do).
I've had noises from dry/slipping sway bar bushings on other makes' cars, but never as often as on our '02 van. (And we have an advantage, the 'touring suspension' :rolleyes: has bigger sway bars)
The third time I replaced the sway bar bushings, I think I glued the bar to the bushings.
I also roughed-up the interface area of the metal bar by gouging them with 'toothy' vice-grips. And as previously stated, I tightened the tab away from the single attaching bolt and provided more tension with a layer of inner tube rubber inside the bracket.
Last replacement was almost almost 7 years ago, 48K miles, with MOOG bushings, according to my records. No noises to date.
· Registered
2005 T&C Limited 3.8
The original sway bar bushing for the 4th Generation was a straight synthetic rubber bushing. It was only about 2005, maybe earlier, that the "nylon" insert showed up within the same rubber bushing to try to solve the noise problem. In the meantime MOOG had the thermoplastic blue bushing, which was used with some success.
Perhaps the wear and tear on the rest of the suspension causes a looseness and more travel and is the straw that breaks the back of a marginal design. The factory installed system seems to perform well for years.
At one point, over the years, a bushing with a fabric interface was marketed, obviously looking for more friction (grab). That type of design seems to be coming back (MOOG).
At another point the Mopar bushing, with the white insert, had a white paste between the bushing and the insert. That didn't last long either.
So, the OE bushings have taken on a life of their own. At least three different designs.
Thanks. This history ought to be a sticky. I don't think there is any doubt you are correct that they were meant to compression grip the bar. It also seems there is no doubt they failed to come up with a design to do that on any sort of long term basis especially once the suspension wears in.
So it seems we are all stuck with workarounds with parts that either mimic the original grip or toss the idea and let the bar rotate. As you say letting them rotate is not likely a great solution since there are various transient vibrations that were designed into the bar that was gripped that you will loose if you let it rotate. But gripping seems an elusive end with after market parts.
So ... for me my bar was polished smooth by the worn our blue poly Moogs so my guess is the cheap ones I replaced it with just weren't up to gripping well. The WD40 I sprayed on it ended the clunk by (another guess) by letting the bar rotate. That won't work for long because either the bushing will quickly wear out of the WD40 will dry out. Still working now though.
A knowledgeable parts guy recommended a different brand black rubber that is wider and more importantly a larger Outside diameter that will in theory grip better. That's my next try. I also got the Moogs with the white nylon insert. The instructions specifically say, "Do not apply lubricant to sway bar or bushings". I don't know what Moog had in mind but generally nylon is intended to be a self lubricating bushing intended to let things rotate. If they clunk I'll try lubing them and see what happens.
In short everyone seems to get this problem and most every fix tried works in the short term and none work in the long term. I'm just going to mess with it till I get something that last a year (ten thousand miles for me) and just keep replacing them. It's great to be retired with time on my hands. :)
· Super Moderator
Wrong! Of course the sway bar will move up an down freely when the bushing is worn and not doing its job. Think NVH (noise, vibration, harshness). It's considerably worse when a sway bar bushing is no longer gripping the bar.
When the bushing is worn, the bar will rotate easily, without being grabbed by the bushing, and will move laterally from side to side as well. Both those movements compromise the purpose of the sway bar system i.e. to counter sway and to dampen down the suspension. NVH
The bar has no collars on it to prevent the sideways movement brought about by forces on the sway bar when steering the wheels. That movement can be seen when bushings are worn.
The only thing that prevents the bar from doing what it's not suppose to do (rotate loosely and slide loosely), is the grip the compression bond imposes between the bar and the bushing. Compression bonding is a common type of sway bar system design, it doesn't involve lubrication maintenance. Chemical bonding, used on some systems, is another type. Are you saying a sway bar is free to move in its bushing with a chemical bond? The bushing bites it's teeth and screws up its face. :) Compression bond and chemical bond both resist movement at the interface between the bar and the bushing. thereby affecting roll stiffness that a standard, free to move bushing design, doesn't. The free to move system design will also require lubricant, either by zerk or periodic maintenance of the lubricant (hard polyurethane bushings).
Sway Bar 101 from: Sway Bar Bushing Replacement
1. STABILIZER BAR WITH CONVENTIONAL BUSHING Note: Bar is loose within the bushing, decreasing the effectiveness of the bar. Also, the roll stiffness of the stabilizer bar with the conventional bushing is 17.7 N/ mm.
2. STABILIZER BAR WITH GRIPPY FLAT BUSHING Note: Flat surfaces on bar and bushing to create grip. Causes stress concentrations.
3. STABILIZER BAR WITH UPSET RING
4. STABILIZER BAR WITH CHEMICALLY BONDED BUSHING
5. STABILIZER BAR WITH COMPRESSIVELY BONDED BUSHING
Take your pick. Which one is it? The installation instructions from both MOOG and Mopar, for the Vans' sway bar bushings, say "install dry, no lubricant", time after time. The Parts guys at Mopar are vocal about that, no ifs, ands, or buts.
By the process of elimination:
  • no chemical adhesive involved, scratch #4
  • no upset ring, scratch #3
  • no grippy flat surface, scratch #2
  • no lubrication required, scratch #1
· Registered
It’s easy to say I’m wrong without disproving my logic. Based on your conclusions that the bar isn’t supposed to move, you still seem to think it’s a torsion bar that is supposed to be keyed/ locked to the chassis, and you couldn’t be more wrong. As if the engineers would try to counteract the weight of the whole vehicle with a smooth round bar in a round bushing clamped in a bracket with 1 bolt…
It literally does nothing, and moves with the suspension, until the suspension load changes unequally side to side, in which case it increases the spring rate of the more loaded side by leveraging against the less loaded side. The bar twisting in its bushings on the chassis is necessary to follow suspension travel. The only fixed position is the attachments essentially to the struts, which only act upon each other through a spring steel sway bar,
· Registered
Jeepman, half man-half Jeep, what you are saying is perfectly true, except, for whatever reason, the compression bonding doesn't work on these vans. A workaround is to let them slip, with very little penalty in terms of handling. My 2003 handled well when the bushings were compression bonded, and handled well when the bushings were slipping. As such, I kind of think the bushings are a non-issue, other than to resist up/down and fwd/backward motion of the bar.
Look at the bushing, and compare them to the two struts and the two strut springs. Remember, the twist/torsion of the sway bar is converted to up/down motion by the end links, which is resisted by the springs and both damped and resisted by the struts.
· Registered
This. The bonding certainly would have some effect on suspension dynamics but we aren't talking F1 here. It's a minivan after all. It seems to me the force of torsion resistance of a rubber bushing on a 1" diameter bar would pale to irrelevance compared to the force the strut links would put on this system. Chrysler engineers apparently would disagree but then they are the ones who got us into this whole mess in the first place.
· Super Moderator
Interesting, thanks. You are right, the compression bonding fails, or at least fails enough to cause noise. The very similar shaped sway bar bushing worked well on the 3dr Generation, I think. The problem seems to be solely with the 4th Generation, perhaps changes in overall suspension design made the sway bar assembly design marginal.
No, the sway bar being bonded to the bushing helps lessen NVH whereas a freewheeling polyurethane bushing increases it. Within the sway bar assembly itself, that decrease in NVH is significant apparently. Keep in mind that your bushings are likely restrained/bonded somewhat even though they were slipping. Most times I have taken off bushings, part of the insert will be stuck to the bar, so there is some remedial bonding.
I was reading about a Volvo that has the bushing bonded to the sway bar. The advice from Volvo and Mitchell is that when the chemical bond breaks, for whatever reason, the sway bar should be replaced. Maybe that's fair advice for the Chrysler system as well, including brackets and end links, i.e. total replacement.
Control arm bushings, trailing arm bushings and such have rubber bushings bonded to their encasements, chemically I assume, and seem to work just fine with the rubber twisting back and forth for years on end. They may even have a couple holes in them to provide some source of stress relief.. Polyurethane replacements act completely different, come in two pieces (easier to replace), and have a lubricant included. Eventually they will squeak, requiring maintenance.
All bushings on my Jeep are original. The suspension is original except for sway bar links, front and rear. The suspension has a lot of travel in it too, the front sway bar bushings are mounted up front, outside on the frame, just behind the front bumper. The OE rear sway bar links were junk, their Mopar replacement links were junk. A Jeep offr-oad Shop said I can fix that, and he did. Thousands of miles later and still good. The links up front are better but even with a Zerk on one end, have to be replaced every 5 years or so. So, Chrysler's design for the sway bar bushings on the 4th Generation gets an F at best. The Jeep gets an A. They are both compression bonded. Go figure. It isn't as simple as it seems.
PS: Did Carbuff2 use gorilla glue between his sway bar and bushing, or what? He likely has a patent pending on his fix. :)
Reactions: Carbuff2
· Super Moderator
Yeah, it's a full time job. :)
The larger bushing mentioned, is likely the MOOG that you have.
I think Chrysler gave up on trying to get the bushing tight enough with a one bolt and tab clamp system to resist the higher occasional stresses on the system (overload), that may cause some movement and some wear on the rubber. I believe the insert to be a sacrificial wear surface as and when needed, something like delrin. I think the grip is not uniform all the way around, causing the slit to open and close (clicking) and eventually wear (clunking). Sometimes, when a wheel is jacked up, the slit opens up a lot, indicating unequal clamping forces/bond breaking.
New brackets with the bushings is advisable.
Maybe Carbuff2 will disclose the full details of his patent pending solution. :)
Reactions: Metalguy22
· Drivin' Maniac
JB Weld. I use that s**t for EVERYTHING. 😇 Seems like it, anyway.
Yes, my fix is patented. Just warning you...
(Though, I COULD have used Krazy Glue...did I ever tell you I have a bad memory?)
· Registered
Seems reasonable. But then the question becomes what do you do with caked on JB Weld on the sway bar in the event the bushing still goes?
· Drivin' Maniac
I was only kidding about the JB Weld for Jeepman's benefit.
But think about this: any lumpy caked-on JBW will grab the replacement bushing better than a smooth bar, the next time you renew them ;) ...
· Registered
Hey, After decades of keeping old clunkers running I know my JB Weld. It's entirely plausible it would work.
· Super Moderator
So, the adhesive you used is still a trade secret. Oh, I forgot about your selective poor memory. :)
  • Haha
Reactions: Carbuff2
· Banned
If you really insist on trying to hold the bar in place, you could always use the urethane that is made for holding auto glass in place. It is incredibly strong yet somewhat flexible. My friend used to Jerry rig stuff all the time with it. You could probably make / form your own bushings with it with the bar in place. It'd just take quite a while to set up.
Or, just do like the off-roaders do.... take the bar and links completely off. No bar = no noise.:)
· Registered
I want to stop responding to this string but, for some reason, I'm compelled:
1. Off-roaders want complete independent wheel movement, which a sway bars would interfere with, but they don't drive down the highway at 80 mph.
2. Regarding NVH, twist is twist and really doesn't add to NVH. It's the up/down and fwd/backward motion of the bar that vibrates the body of the van. This motion is normally isolated by the rubber sway bar bushing, whether the bar is prevented from twisting or not. Urethane, being hard, does not isolate the body from the motion of the bar, and all the up/down and fwd/backward is passed to the body of the van.
· Super Moderator
Many offroaders use quick disconnect links. Quadratec has lots of modification parts for Jeeps. Some could possibly be used on the vans. :)
Maybe someone will try that urethane in the system. Might work, couldn't hurt. I know the product, been used on a new bottom moulding for the rear window on my Jeep. Perhaps Carbuff2 will modify his "patent pending" to include. :)
· Super Moderator
Looks like you have been doing your homework. :)
Should go back to solid axles with link hooked to an axle instead of a strut that steers.
· Banned
Oh, please do so.;)
Ya think? I was being facetious when I suggested it, hence the smiley face. Geez.:rolleyes: Some off-roaders actually do daily drive without sway bars. How much it affects the handling depends on the vehicle. And, over the years, some vehicles even came from the factory without them. I have actually owned a couple of them.
Yeah, like you are going to feel the little tiny bit of difference urethane would make by "not isolating the body from the motion of the bar". Especially when the subframe is mounted on rubber bushings.:sneaky:
