I want to know if I can put the tires from an Aerostar tire size (P215/70R14 96S)
On my 95 Grand Voyager tire size (P205/70R15 95T)??
You're gonna have to stretch those 14" tires A LOT to make them fit on 15" wheels! If instead, you were planning to swap the entire wheel assembly you need to be VERY careful. The most obvious problem would be the bolt spacing (which is likely different). More important is the wheel offset distance from the rear of the rim mounting surface to the tire bead (again likely different) and the width of the rim (likely different). Putting wheels on with different back spacing is dangerous (bending moment from centerline of rim may be a lot larger than Dodge intended for the spindle's design). Finally, last I checked the Aerostar was rear wheel drive. Those rims will be different than a front wheel drive Voyager rim. Not gonna happen.I want to know if I can put the tires from an Aerostar tire size (P215/70R14 96S)Â On my 95 Grand Voyager tire size (P205/70R15 95T)??
My idiot cousin did that by accident once.Originally posted by AMD Rules@Feb 2 2004, 07:41 PM
