Trans slipping after waterpump replaced?
1481 Views 3 Replies 3 Participants Last post by  TC2011
Hey all, I had my 2011 T&C in the shop for water pump and serpentine belt replacement 3 weeks ago. I noticed it felt a little shaky at start up after the repair. Now all of a sudden the transmission is slipping. No check engine light yet. Could this have anything to do with the recent repair?
Backstory- I did have a check engine light about a year and a half ago (P0740- Torque converter) Took it to trans shop, he topped off the fluid and everything was good. About 9 months later, same check engine light code came back. Took it back to trans shop, he said likely rebuild, they couldn't see any issues. Light went off on its own and hasn't been on since (5-6 months ago). Car was driving fine when I had check engine light. Didn't have any signs of trans issues before water pump and belt were replaced.
I've been told the trans fluid is finicky on T&C's, is that true? I've had mechanics tell me it's been overfilled & underfilled. I'll add- the mechanic who told me it was overfilled, underfilled it. It was after he did a repair that the check engine light came on initially. I brought it to trans guy, who said fluid was low.
Any insight appreciated!
1 - 4 of 4 Posts
It wouldn't hurt to ask the mechanics what they noticed. I don't see how they could wreck the tranny though. They wouldn't of even touched it. Maybe they had fun on the test drive though and that was enough to trigger past deficiencies.
There's no denying 62TE is a POS tranny all in all. Some have had good luck but many have had bad. I would extract and replace 4 litres 2 times and see if it helps.
Maybe back when the transmission shop looked at it they put in universal fluid instead of atf4?
Reactions: 1
No connection.
"Low" doesn't mean anything. There is a cold level range and a hot level range and it has to be checked properly. Low could mean the level is at the low end of the range and that's fine. It says on any dipstick not to overfill, so that's not fine. Being a little below a range isn't a big deal as the transmission contains a lot of fluid.
I don't think the transmission fluid is finicky other than it should be licensed ATF+4.
As for the transmission itself, it's based on the 41TE and is quite dependable, less problems than the ZF based 8 and 9 speeds used by various manufacturers, including Chrysler.
Check at CarComplaints.com | Car Problems, Car Complaints, & Repair/Recall Information for common complaints by year.
Remanufactured 62TE Transmissions: Specs & Cost
62TE Troubleshooting, Diagnostic Help!
See less See more
No connection.
Thanks, I'll take a look at this.
I noticed on the paperwork from the shop that they added trans fluid which is why I'm wondering if there's any relation to the transmission issue. Not sure why they added fluid?
1 - 4 of 4 Posts
