Hi,
I changed transmission fluids and filter during the weekend. I used ATF+4 (Valvoline) as mentioned over and over on this forum. Unfortunately I didn't have access during the weekend for Mopar fluid so had to use other brand.
My minivan is Chrysler 2004 Town & Country Limited, 3.8 L, 2 wd and I have 142000 miles on it.
I was told that I need 4 qt but when filling I luckily checked after 3.5 qt and found my dip stick shoving low end on the "hot scale", naturally engine and fluids were cold.
I drain old oils by dropping oil pan. I replaced as well RTV seal by rubber seal which came with the transmission filter.
Please let me know how much fluid is needed and do I need to drain extra fluids around 1/2 qt?
Anyway I got leaking RTV seal fixed. No drips on the garage floor after two nights! I as well tightened transmission solenoid to prevent leak from there.
Thanks in advanced!
Thanks in advanced!
