Transmission interchange
1 reading
7K views 4 replies 5 participants last post by  atoman
#1 ·
Hi everyone I have a 2005 Chrysler Town and Country LX with a 3.3 L V6 and I have a parts van that is a 2003 Dodge Grand Caravan ex with a 3.8 liter V6 and I would like to know if the 03 with a 3.8 V6 transmission will fit the 2005 with a 3-3 V6
#4 ·
The final drive ratio is different, but the PCM won't care. The pinion factor is stored in the PCM/TCM. Your speedometer will be slightly off, or you can have the PCM/TCM recalibrated, or you can swap the differential ring gear, transfer shaft(pinion), and transfer gearset from the old transmission to the new one.
