1 - 3 of 3 Posts
Does the tag id on the 62te matter much? are they geared differently or anything. My transmission is a p05169713AB and the one that Autozone ordered was a 68039386AB...Had a garage install it now it wont seem to shift out of first gear. I was told it had 2 codes in it which is p0731 code. And a p0944 which i believe the 2nd was still stored in there from when the transmission was going out on me. I didnt know about the tag ids until i was told by the mechanic. i was just wondering if anyone knows if they are able to be used with no issues with each other or do i need to order a whole new transmission and pay about another 600 in labor. I was told the codes need to be taken from the system and a whole new quick relearn but im not convinced this will fix it. Please help if anyone knows out there. All i know is they are both 62TE transmissions.
First thing is he needs to reset the transmission
Need a scanner to relearn shift points. The codes you have could be from old transmission so those need clearing.
1 - 3 of 3 Posts
