I have an 05 Town and country 3.8 touring. Trans went out and I replaced it with a used trans with only 40k miles on it. It's stuck in limp mode and am wondering if it needs some kind of reprogram or reset.
P1776, p0846, p0841,p0732No reprogram or reset is needed. Does it have any codes set?
if no codes, it’s likely going to mean checking power and grounds. FWIW, with no power to the TCM or transmission you have limp-in mode.
Yes. I was just hoping it was in need of a reset.Have you tried to find out anything about these codes?
Did you check the fluid level and look inside the trans pan?P1776, p0846, p0841,p0732
I'm nowhere near a pro. But I did swap the solenoid pack with my old one. It's hard to figure out how much fluid is in the transmission.Yes. I was just hoping it was in need of a reset.
It shouldn't be, if you do it rightIt's hard to figure out how much fluid is in the transmission.
Lmao! I know how to check the level but, the dipstick is wet all the way up from filling it.So, wait a second. You were able to swap transaxles on a 4th gen van, which is not all that easy, but you don't know how to check the fluid level? Is that right?
I had the p0846 and p0841 codes and it turned out my TCM module was bad and needed replacement. It would drop my van into limp mode sporadically. I thought my tranny was bad but it was the TCM. It was a real pain trying to find a replacement for my 2001.P1776, p0846, p0841,p0732
I don't think it's the tcm because my other trans never went into limp mode.I had the p0846 and p0841 codes and it turned out my TCM module was bad and needed replacement. It would drop my van into limp mode sporadically. I thought my tranny was bad but it was the TCM. It was a real pain trying to find a replacement for my 2001.
Can a bad PCM cause intermittant gera change issues?
Hi, I want to start off by saying I am homeless and live in my van so keep that in mind when thinking about my situation. Thanks! My 2001 DGC Sport, 175K miles, is in the shop the mechanic said the PCM was giving out a bunch of codes and I need a new one. I brought it in because , not all the...www.chryslerminivan.net
P0732 - "Gear 2 incorrect ratio"P1776, p0846, p0841,p0732
If that's the case an hour (or even 15 min) after filling, it's overfilled - ATF+4 is low viscosity and will clear the tube pretty quickly.the dipstick is wet all the way up from filling it
