Any rust scale build up near the rotor "hat" that may be causing the pulsing. If so, this can be chipped off or ground off. There could be a heat response there as well because the scale would tend to expand unevenly, I would think.
Any rust scale build up near the rotor "hat" that may be causing the pulsing. If so, this can be chipped off or ground off. There could be a heat response there as well because the scale would tend to expand unevenly, I would think.I am running an 03 Caravan with about 120k on the clock. I had to replace the front pads at around 80k which I understand is not unusual. So far, they have been great. The last few months though, the brakes feel fine when starting off cold, but, after a few km I can feel a definite pulsing which gets progressively worse as the day wears on. I pulled the front wheels a month ago (cold) to have a look around ... the ceramic pads seem to be doing a great job, everything nice and clean and surpriseingly, the runout appeared to be normal. I torqued the wheels back on just to insure they hadn't been rotated by a hack when I replaced the tires at around 110k. It road tested about the same afterward, like the rotors are overheating. I am thinking the ceramic pads, since they wear so well, must be generating a bit more heat than stock pads so I'm going to replace the front rotors. Since price is not necessarily an indicator of quality I'm wondering if anyone can suggest suitable replacements. By suitable, I mean high quality at a reasonable price.
If your talking about the address for the pipes, click on the right hand upper corner, the white triangle with a black line in the center and the red border and ask the administrator to do it.Wow..nice and interesting. i will try it later. Thanks for sharing information. Thanks for the comment, are you talking about the whole designing or a part of? Not bad. Have you done this type of stuff often? It seems like it. i like the idea but how do members of the public remove there details. stainless steel pipe
So you are saying that you have 120 on the original rotors with 40k miles of it on ceramic pads? If so, then you need rotors no question about it. The rotors are worn thin and can't absorb enough heat anymore.I am running an 03 Caravan with about 120k on the clock. I had to replace the front pads at around 80k which I understand is not unusual. So far, they have been great. The last few months though, the brakes feel fine when starting off cold, but, after a few km I can feel a definite pulsing which gets progressively worse as the day wears on. I pulled the front wheels a month ago (cold) to have a look around ... the ceramic pads seem to be doing a great job, everything nice and clean and surpriseingly, the runout appeared to be normal. I torqued the wheels back on just to insure they hadn't been rotated by a hack when I replaced the tires at around 110k. It road tested about the same afterward, like the rotors are overheating. I am thinking the ceramic pads, since they wear so well, must be generating a bit more heat than stock pads so I'm going to replace the front rotors. Since price is not necessarily an indicator of quality I'm wondering if anyone can suggest suitable replacements. By suitable, I mean high quality at a reasonable price.
