I don't know but I have one also
By the battery behind the headlights, right?I don't know but I have one also
Mike S Grand caravan 3.3
NoPerhaps it has a home in the IPM when other accessories are included.
Mike, will it reach the IPM / TIPM?
I don't have fog lights, so, maybe you're right.Do you have any notable lack of options, like foglights, etc?
You're right!By the battery behind the headlights, right?
Don't worry about it I found it on my van and went to the junkyard and all the vans had itYou're right!
To be honest, my minivan is a little bit messed up.
I had a problem with tailgate latch, ABS, airbag... so, upon the "recommendation" of other T&C owner I drove to diagnostician. Even to this day I find unplugged connectors...
*T&C 2004 3.8L
No power adjustable pedals.As I mentioned previously, the configuration is for a relay (to plug in). Take a look at the blades on this male portion of a relay.
Compare that with the receptacle the OP provided a picture of. That's not an ordinary electrical connector. It's a receptacle for a switchable relay.
Perhaps it's for towing or being towed. Does the TIPM have a relay location for power adjustable pedals. What relay location is missing from the black box?
It's definitely made for a relay to plug directly in. If the fuse/relay box doesn't have a location set aside for adjustable pedals relay, even though no relay is there, then that could be it's purpose. Anybody with adjustable pedals could confirm this. A wiring diagram should/might show this as well.No power adjustable pedals.
Relay box has no missing connectors, relays.
One guy on the internet told me it's "adjustable panel relay". But, I don't know what it means.![]()
