1 - 5 of 5 Posts
2008 Chrysler T&C Touring
MY ABS, ESP and traction lights lit up last week. I got the codes from the ABS module that said the driver's side sensor was bad. Ordered one and got it in yesterday.
This morning I decided to replace it. Upon removing the wheel I discovered that the wiring had ripped out. Apparently it came loose and wound around the axel and is now gone.
The end of the replacement sensor wire mounts to the underbody with 2 push through fasteners. There are no remains of that end of the wire and there is no wire to attach to. I am guessing it pulled part of the harness out as well.
Does anybody know where the sensor harness routes through the endgine compartment? I have no idea what wire I am looking for now.
Thanks... If any of you happens to have some pics of it, that would really help to.
A lift won't help here. That wire connects to the main harness behind the fender. Pulling the battery tray might get you a clear shot at it.
Reactions: rubantin
1 - 5 of 5 Posts
