1 - 18 of 18 Posts
Some of the trim pieces that border the "wood" grain on my 1992 Plymouth Voyager are dented, and I would like to find replacement pieces before I put the new vinyl trim on them. Who has a 1991-1995 "woodie" Plymouth that can sell me some pieces?
Not sure if this is a match ...
Here are the 3M vinyl automotive wood grains on vehicles.
https://www.customautotrim.com/vinyl-wrap/wood-grain-vinyl-wrap/
3M DI-NOC wrap films are the best in the industry. Not just for architectural applications, this wood grain vinyl wrap gives a whole new look to vehicle interior and exterior applications.
Can't find a wood dash kit for your older vehicle, or find a molded wood dash kit for your newer vehicle? Do you hate the factory trim finish on your dash? Then try wrapping your vehicle interior surfaces with beautiful wood grain vinyl. Peel and stick application, this vinyl will wrap and conform to curved surfaces that regular wood dash veneers cannot cover.
Restoring a classic car? Restoring a woody wagon? We have wood grain vinyl for the Town & Country wagon,
Please explain, seems like some people don't understand what "trim pieces" are.
For reference:
The basic wood grain vinyl is applied right on the sheet metal. Bordering the "main" vinyl, are trim pieces on the top and bottom, which go along the sides and the rear hatch. There are also "trim" pieces around each wheel well opening.These trim pieces have a lighter color of wood grain, compared to the darker main wood grain. These trim pieces or bars, are held on by screws around the wheel well, and by plastic clips everywhere else. Hope this wordy reply helps.:) I will take some pictures tomorrow or Saturday and post them here.
Discussion Starter #6
We all like pix.
Apparently I can only post one picture at a time? The size is too big for this website? The attached picture shows the trim piece below the gas cap and also the front of the trim above the LR wheel well, that I would like to find replacements for. I will attach more pictures in another reply
Discussion Starter #7
This picture shows the lower trim below the dark wood grain on the sliding door. If I can find a good piece then I won't mess with trying to straighten it. Another picture will follow.
Discussion Starter #8
Here's the third and final picture. I know this is a common problem with many of the paint jobs in the past and some say even recently. Somewhere I read that the car companies decided to prime vehicles ahead of time, but by the time the car was to be painted with the color scheme requested by the customer, the primer had lost some of its tackiness, so the finish coat didn't stick as well as hoped for, which was an invitation for the paint to flake off just like the picture shows. The only cure I know is to do a complete paint job. Any other thoughts out there?
That link I had provided prior, your rear vehicle picture looks like their 3M p/n #DN-WGHICK
Your thoughts?
I assume that because you said it is a 'Voyager' that it is not a 'Grand Voyager'. I might still have some pieces off of a 93 Chrysler T & C, but would need to go look. The GRAND Voyager and GRAND Caravan are, as I understand, the same body as the Chrysler T&C, but the other model is a shorter body, so some of the trim pieces would be different. (I stripped & scrapped this vehicle almost 10 years ago now, and have sold some parts over the years, so would need to look before I could say that I have any of these pieces at all.)
oh my. That seems to have been a common trait with the trim molding for a few generations of these minivans. So, it's the lighter grain eh.
See that link above again and look at the 3M DiNoc Wood Grain Vinyl Wrap - Pale Teak then Part :#DN-WGPLTK
It would be a trick to re-cover the molding vs. a body panel. Even with a hair dryer to get the bubbles out in those tracks would be a job. In a production process, a heat plate that is surface offset would overlay the vinyl to the molding. Not sure what a collision shop would do or the tricks they would know.
Yes, looking for donor parts seems ideal, but how many are left and their condition of the moldings? And if you did find a good one, how long would it last due to the age? hmmmm
There is a good deal of molding on the woodie versions. To just strip and paint would be a work as well.
A time perplexing problem here.
Discussion Starter #13
Sorry for the delay in replying to your post, as I've been working on the siding on my house, and winter and cold weather will be here before long in Minnesota. Did you find any of the pieces that I am looking for?
I know that I have one off of one of the front fenders, but I don't even remember now which side it is from. I didn't look for the others, as I was still wondering if you have the Voyager, or the Grand Voyager. (From the pictures, it looks like the Voyager, which is a shorter body than the Chrysler Town & Country.) But I'll go up in the attic & see if I still have any of the other trim. It was going on 10 years ago when I dismantled the minivan, and I also sold some stuff years ago. Almost everything that is left is up in the attic. The one piece I saw recently does have the same issue - the plastic wood grain film is dry & peeling off. I think that I would experiment with painting the wood grain back on. Yes, it is an art, but I'm facing this same issue with my 46 Plymouth. (The dash and all of the inside trim is wood grain.) This modern trim would be a lot easier, because it is relatively straight, w/o a lot of complex curves. The challenge might be finding the right kind of paints to use.
Hello.
I hope you have found the trim pieces you wanted for for Voyager/Town and Country.
Another problem that you may have (and i also!) are the plastic that go from the inside of those trims and "catch" to the body of the van.
They have a number 6004178 but nothing can be found on my Internet searches.
Does anybody have a solution to this problem?
My Van was repainted from the previous owner, and some of those are broken. :-(
Any help would be appreciated.
Hello.
I don't have any experience with the "Woodie" trim but you might try looking at this website to see if they have anything that might work. I see they do have a clip for the "Woodie" trim but it has a different part number (6004162). I searched for all Chrysler clips. Automotive Retainers, Clips and Fasteners - ClipsAndFasteners.com
Thank you for your time for searching.
I saw the clip you suggested. It is quite different, but it is a good start!
Since you gave me a starting point, i will try to email them and sent them the picture with my part number.
Maybe they also have it, but since it is for a much older model maybe they dont have it uploaded to their site!
Thanks for the help.
I have great problems to keep it in good condition here in Greece, since it was never imported from the dealer.
I have bought many parts from USA and imported in Greece, with great cost in import taxes!!!!
1 - 18 of 18 Posts
