So, an ironic, karma filled story....
Earlier in this thread,
@Jeepman diplomatically corrected a recommendation I made to
@delhiboy3732 to coat the trans pan gasket before reattaching the pan to the vehicle. Jeepman included links to Fel-pro’s website where they explained why lubing the gasket prior to installing wasn’t necessary because of technology used in modern gaskets.
I’m changing the trans fluid today. I replaced the OE pan with the Dorman pan that has a drain plug.
I drain the fluid from the OEM pan and leave the old fluid laying near the trans but a little bit out of the way toward the rear of the van.
I’m laying there with the new pan and Fel-pro gasket trying to get everything situated so I can put the new pan up there and fasten a couple bolts so I could use both hands to fasten the remaining bolts.
Guess what happened? Half of the new gasket slipped into the old trans fluid!! 😂
I wiped it off the best I could. We’ll see how it holds up.
I torqued the bolts to 60 in. lbs. No leaks thus far after ~20 miles of driving, no leaks.
I’ll drain and refill the next two weekends using the drain plug.
