I bought a 2005 Grand Caravan with a 3.3l last summer. Previous owner told me about a misfire, said it probably needed a tune up. I started with the simple stuff, plugs, wires, ect... None of witch solved the problem. Being an older vehicle with close to 100k miles on it I figured it could use a little cash thrown at it so I moved on to replacing the coil pack and EGR valve. These also did not work. After a little research I found out about a TSB for plugs, wires, and PCM flash. Took it into local dealership an paid to have the PCM update done. Problem still not solved. Local dealer then diagnosed it down to a bent connecting rod......... never heard that before. Brought it home with nothing but faith in thier expertise.....lol, proceeded to do a compression check. Number 6 was down about 70 PSI, and at top dead center was down a little less than 1/4 inch below the others. I am now assuming the dealer was right.
Is it possible on these to replace a rod from underneath?
If so what is the best way to compress the rings from there?
If anyone has an answer for me any specifics on this job would really be appreciated!!!!
