I have flushed out all of my old coolant multiple times so that my coolant is now running real clear. The problem is now that I have pretty much 100 percent water in the cooling system, I don’t see how I am going to get the proper amount of antifreeze back in.
When I open the drain plug at bottom of radiator I only get about 6 quarts coming out. I want to put enough antifreeze back in to achieve a 60 percent mix of distilled water and antifreeze, and to achieve that mix, I figured I need to put 9.78 quarts of antifreeze back in.
The owner manual say there is 16.3 quarts total in the cooling system, and that includes the coolant recovery bottle filled to max, and 2.9 quarts for the rear heater. So, 16.3 quarts times 60 percent mix requirement = 9.78 quarts antifreeze.
So, the question I have is after doing the complete flush that I have done, how do I get at least 9.78 quarts of the distilled water back out, so that I can add back in the 9.78 quarts of the antifreeze required to achieve a 60 percent mix of distilled water and antifreeze?
