My 2013 T&C Touring-L had the lights when I bought it.
To be honest, they are really rather useless. They aren't high enough up to work as driving lights and they aren't designed to be actual fog lights. All they do is light up the area under the front bumper for a distance of about ten feet or so in front of the van. They use the same bulb as the headlamps, but there is no lens to diffuse the light properly for use as fog lamps and they don't shine out far enough to be useful anyway.
If you really want fog lamps that work, I'd go with something after-market and don't go cheap. For best results as fog lamps, they should be yellow or amber anyway.
My van has the auto high-beam lights, and the 'fog lamps' go off when the high beams go on. When driving with cars coming at you, your high beams go off, but then the lower 'fog lamps' go on, and I've had other drivers turn on their bright lights at me, thinking, I assume, that I'm doing the same to them. I really haven't used them since I got the van.
