Have a torn passenger CV boot, and driver side is showing quite a bit of dry rot, so replacing both. (‘08 T&C Limited / 4.0L 62TE transmission)
This will be the first time doing this for me, and while there are quite a few videos and posts here on axle replacement, I’m not seeing anything specific to Gen 5 minivans on axle seal replacement while I’m in there.
So seeking some knowledge on the process, requirements, tools, etc., to avoid not having everything needed prior to starting the job.
The passenger’s side inner axle splines appear to be female, while the driver’s side inner axle splines male.
It seems the axle seal on the driver’s side is far more exposed and would be easier to replace. Does a passenger side axle seal exist and/or need to be replaced like on the driver’s side?
What are the best tools to remove the seals and, possibly more important, what tools / makeshift tools do you all use to install the new seal?
