Crazy factory Trans pan RTV and aftermarket torque specs...
15K views 12 replies 8 participants last post by  171786
#1 ·
Well, the dreaded left hand radiator leak got me the other day. After replacing it yesterday I was feeling fairly motivated, so I went ahead and replaced the transmission filter.
Holy crap, that factory RTV is insane! The bolts are merely a formality! I didn't have the special tool, so I resorted to turning the wheels to full left. I took about a 9" length of 2x4 and placed it longways on the lip of the pan that sticks out on the driver's side. A few whacks with a hammer and the pan unseated.
Having done trans filters a time or two, I've learned to leave the corner bolts in place, only backed out about a half inch or so. That keeps the pan from falling down and throwing fluid everywhere.
I used a Scotchbrite pad to get rid of the RTV remnants and make everything super smooth.
I purchased the AC Delco replacement filter and it comes with a rubber/cork gasket. The factory torque specs of 165 in lbs are for the RTV application from the factory, and am pretty sure that is too tight for an aftermarket gasket. I went with 115 in lbs, and so far it is bone dry.
The old filter was quite dirty and now she shifts oh so smooth! Could be placebo effect, but I'm happy either way...
#3 ·
I too leave the corner bolts in and drop the pan in stages using the rear bolts, leaving the front ones in (loose) until enough fluid has drained from the pan to remove it completely. It only takes once to figure out "you're doing it wrong."
#4 ·
From the gospel according to Haynes:
"Place a container under the transaxle pan and loosen the pan bolts. Completely remove the bolts along the rear of the pan. Tap the corner of the pan to break the seal and allow the fluid to drain into the container (the remaining bolts will prevent the pan from separating from the transaxle). Remove the remaining bolts and detach the pan."
Brake cleaner works for removing RTV.
#7 ·
On my first Trans. filter and fluid change I syphoned out as much fluid as I could through the fill tube. I did leave the 4 corner bolts in and didn't miss one drop outside of the drain pain. But this is what got me. When I removed the filter, fluid got every where. (lesson learned)
#8 ·
itsallgood, Thanks for the reminding me that I forgot to mention that! Yes, the filter will 'pop' off and will have quite a bit of fluid in it. I kept my drain pan under it. For those doing this job, the rubber o-ring for the filter may stay up in the trans, so make sure you fetch it before putting in the new filter. Also, the filter has plastic tabs that keep it held in place. Set the new filter up into the trans, then give it a solid whack with your fist to push it up so it locks into place.
#9 ·
I've never liked this system. It always seems like it will fall back into the pan. That said, after numerous pan drops, I have yet to see one come off. I installed a Dorman pan with drain and a 3/8" Magnefine fiter, so now I feel comfortable leaving the pan on for a few years at a time.
#11 ·
:) Same here when I finished spraying my vehicles with Fluid Film. Smelled pretty sheepish too.
Fluid Film® is formulated from specially processed wool-wax, highly refined petroleum oils and selected agents to provide corrosion control, penetration, metal wetting and water displacement.
Likely smelled like a rose compared to the aroma of your ATF+4. :)
#12 ·
It does seem like an odd system at first, but there are some fail safes built in. It's unlikely that the tabs would break, so the filter should remain firmly in place for its service life. Before reinstalling the pan, a couple good tugs on it after installation will show that it will not fall. Lastly, if you look at the bottom of your trans pan, you'll notice 4 quarter sized indentions. Those indents are directly underneath the filter and remove any clearance between the filter and pan, thus it physically cannot fall out of place.
#13 ·
Just an update for those that may search this in the future, I put 700 miles on our van over the holiday weekend. The trans pan is bone dry and the cork gasket is not bulged or deformed in any way. It looks as thought the 115 in lb torque spec is perfectly acceptable when using aftermarket gaskets.
