Engine stumbles between first and second gear
36K views 34 replies 15 participants last post by  Quasimodo
#1 ·
Hey all:
Trying to diagnose a problem. Our 2003 Grand Caravan seems to occasionally be stumbling or hesitating when shifting between 1st and 2nd gear. Everything runs fine otherwise shift wise. The shift between first and second is always noticeable but doesn't always create the stumble for lack of better term.
Just had the transmission flushed and filled and the problem is still there. Engine has 41,700 miles on it... Not a lot and we bought it at 38,000
Thoughts on what it might be or what we might be looking at repair wise?
#3 ·
The hesitation seems to happen most when you are stopped at a light and give it gas to go. Or have just backed out of the driveway and have just put into drive.
Doesn't seem to happen otherwise. Does that make sense?
#7 ·
Try replacing the TPS sensor first.
It is under $20.00 and they are known to cause those issues.
BWD/SMP & Airtex/Wells re-designed theirs using hall-sensors and they are more reliable now.
(The older ones had solder joints which were prone to failure)
http://www.wellsve.com/advantage_throttle.html
#9 ·
Mine does the same thing, just as described. Other than this, which happens every once and a while and usually under light acceleration / light throttle, everything runs great. Trans shifts nice and firmly from Reverse to Forward and vice versa. I have noticed a very slight leak, that appears to be coming from the solenoid pack from what I can tell. I just had surgery a few weeks ago so I can't really get under there and take a look at everything yet. Mine has about 71K miles on it.
#10 ·
Ok, wanted to follow up on this.
We finally decided to bring it up to the dealer. They hooked it up for diagnostics and also said the that the transmission looked good and didn't seem to be the issue.
Recommendation came back for two things - 1) replacing the spark plugs and wires (they were original and most likely were never done by the original owner and 2) there was a code update / firmware update for the computer. They said it didn't specifically address that issue but did have something to do with shifting.
Anyway, got it back and the shifting problem is gone. Also noticed that shifts now take place at about 15-17 mph and before they were taking place at 10-12mph.
Today also did a fuel injector cleaning as well.
Car is running like new.
#17 ·
For what its worth... My 1st to 2nd gear stumble feels a bit like missed shift in a manual transmission car. It will buck harshly 3 or 4 times then smooth out. If I left off the gas for about a half second slightly when I feel it starting to happen I can avoid the worst of it. My van has all wheel drive and a neighbor had a 2002 AWD GC with the exact same issue (for all 100K miles of ownership - never solved by dealer) so I've always thought it had to do with AWD. Really would like to solve as it affects driveability - and I have a new teen driver coming on soon.
#18 ·
where have you seen a teen driver low throttle 1-2? :)
Most of these vans have a 'stumble' given the right conditions and it usually gets worse as the fluid wears. Things that seem to diminish this 'condition' are 1) consistent driving (helps the computer predict what's about to happen) and 2) good electrical connections (grounds and power) + good/stable power supply (no spikes/drops in voltage).
#19 ·
Following Up
Hey LEVELBEST, what did the issue turn out to be? I have the exact same issue with my 2003 Grand Caravan. Under light acceleration it does what I call a quick 1st-2nd-1st-2nd-1st-2nd and then off it goes. All in about 1 second. I'm thinking about replacing my transmission control module. Did they just reprogram the shift point?
#20 ·
I have had this problem since I bought my 2003 AWD Grand Caravan five years ago with only 38,000 miles on the vehicle. I replaced the input and output sensors three years ago, which did not solve the problem. I read this thread two days ago, replaced the throttle position sensor yesterday, and the problem is gone! What a simple fix - a 24 dollar part and less than a half hour to install it. Any backyard mechanic could do it.
#22 ·
I guess I never saw this Topic. Have contributed to other similar ones.
Our 2002 3.8L van has exhibited this 1>2 'buck' or stutter under light throttle for many years and 1000s of miles. It never happens with a cold engine or with increased throttle pressure.
Supposedly it is a result of engine control providing too lean of a mixture at light throttle.
It will become a non-issue once you develop the muscle memory to depress the accelerator a bit, just before the shift occurs. Not enough gas to increase acceleration, but just enough to inject more fuel.
Interesting sidebar: About 4 years ago, I had the wiper cowl off so I removed the spark plugs, cleaned and gapped them. The stutter went away for 2 months!
#23 ·
This is good to know but unfortunately for me I replaced the plugs, wires and coil pack but still have the issue. I changed the tps and did a transmission relearn this past weekend but still notice it regardless of a cold or hot engine.
After reading over several post here and on other forums people have had good success after changing the shift controller and input/output speed sensors. I plan to do that next along with changing the fluid/filter and doing another relearn. After doing that I’ll report back here with the results.
#27 ·
I had this issue with my 2004 GC SXT. I had the transmission fluid changed with new filter, no change.
After reading a post somewhere I did it again except this time I did it in my shop.
The transmission oil pan was sealed with liquid sealant (likely factory).
Filled the transmission up and checked the level while engine was idling.
The problem is gone.
#28 ·
I want to give an update on my situation. Last weekend I had my tps sensor replaced with a NGK/NTK model and had the throttle body cleaned up. The mechanic also reset the idle and then performed a transmission quick relearn with a programmer. After doing this the van drives and shifts like new. If anyone else is having the 1-2 shift issue I suggest doing this.
From what I’ve read on here after changing the fluid and filter you should do a transmission relearn or a quick relearn with a scanner before driving very much. I’m glad to read changing fluid and filter fixed your issue though, that’s what I was going to try next if the tps sensor didn’t correct the issue.
#33 ·
Just reposting same info with out the strike through. lObviously hit an extra keys somehow.
Fitler won't hurt, but remember 2 different operating conditions, the stumble is lower fuel flow, therefore can be injectors, fuel filter would mostly restrict at high flow rates therefore the engine needs to be say 4000 RPM + before that would show as a problem So don't expect filter to be a fix.
Spark can also show up under high load & low RPM and unless you can feel the difference between a fuel problem and an ignition problem, and (usually I find fuel to be not as sharp a discontinuity as spark but been fooled also and it was the other to fix it.) Ive had bad coils and sometimes the plug or spark plug wire So some additional thoughts for you if the current path doesn't fix it for you.
#35 ·
My problem returned tonight unfortunately
The van was driven close to 200 miles and everything worked absolutely excellent. The first to second shift was as smooth as butter and around 1800-2000 rpm every time.
Today while on the highway a truck pulled out in front of us and my wife had to slam on the brakes, almost locking them up, and go to the side of the road. She didn’t come to a stop just slowed way down really fast and then continued on the highway.
After that during the next stop and acceleration the problem returned and has continued all day. The van now shifts from first to second at 1300-1500 rpm and bucks 1-3 times. Before the slowdown the van shifted correctly.
Why would a very abrupt slow down cause this problem to return and the shift to change to a lower rpm? The only thing I can think of is either the input or output speed sensor is going out and the quick relearn corrected it and after the hard slowdown it got out of wack again.
