My dashboard guages are completely dead (e.g., speedometer, turn signals, tach, check engine lights) on my '01 Voyager. The only thing that works are the lights that illuminate the guages that go on with the headlights. I took out the guage cluster thinking that harness that I disconnected a month ago to replace the panel lights was loose, but that's not the case. Anyone know what would lead to this failure?
I tried the reset procedure by holding down the odometer button but had no luck. I haven't checked the fuses, although if it were a fuse problem, I'd think that the lights that illuminate the guage lights would also not work, but perhaps they're fused separately. Something that may also be relevant, the rear window washer sprayer isn't working, something the dealer blames the BCM.
