How to disable auto lock on 2002 town and country?
3.7K views 3 replies 2 participants last post by  georgef
#1 ·
I don't want my van to lock automatic at 20mph. Does anyone know how to disable? Thank you
#2 ·
The information you are looking for, and much more, is in the following thread: Owner programmable Features
I've copied the specific procedure you need below:
The Automatic Door Locks can be enabled or disabled by performing the following procedure:
1. Close all doors and place the key in the ignition switch.
2. Cycle the ignition switch ON/OFF four times ending i in the OFF position, (do not start the engine)
3. Within 10 seconds of the final cycle, press the interior driver's door lock switch to the LOCK position.
4. A single chime will sound to signify that you have successfully completed the programming.
You can turn the feature back on by repeating the above mentioned procedure or by performing the procedure in the Electronic Vehicle Information Center (EVIC), Customer Programmable Features section on vehicles so equipped.
Reactions: Bobstown&country
