Hi all,
About 2 months ago, saw my PS fluid was pretty brown so I flushed it good with a hand pump several times. With clean, red ATF 4 I immediately noticed PS got worse. I quickly tracked down all the sludge in the old reservoir with a flashlight. This is most likely b/c the fresh fluid cleaned out the system and dumped it on the screen. I replaced it with the new Dorman tank on Amazon that is pretty highly rated at a good price.
PS improved immediately with clean tank but within days got sluggish again and with some slight shuddering especially when hot. I quickly discovered the cooler down by the road was caked with road grime combined with possible oil etc.. I power washed the cooler nice and clean and PS got great again even on hot days.
A few more days and I noticed the shuddering on slow turns creeping back yet again !! Couldn't believe it.
I put front end on jack stands and turned wheels lock to lock 15 times. Solved problem again....but sigh....only for about another week.
So finally..... I take the brand new rez cap off the properly filled tank and I hear POP! Full of pressure and fluid nearly splashed out at me. Naturally, I thought "Oh good" this is leftover pressure from when I bled the system. I put cap back on and PS good for another few days. Then it started slowly shuddering a little bit again.
I am now at the point where after having to take the cap off every few days I realize something isn't right.
After reading all info on this forum: I went through checklist
1. I have not lost a drop of fluid, no leaks
2. Put van front end up and closely inspected steering rack, hoses, cooler for any leaks or damage and found none. I was pleasantly surprised because the rack looks better than I was expecting. (This is a California van)
3. PS Pump makes no whining noise etc.... or gives me any feedback to believe it is bad. Afterall, the PS works great when the tank is not full of pressure.
I had saved the old reservoir for a month just in case and finally threw it away 2 weeks ago. Dohh!!!! Now I am kicking myself because I would kill to get that old cap back just so I could even look at it. I am curious as heck just to inspect an original cap to see if it is vented. This new cap from Dorman appears to have no holes for venting system whatsoever. Just even the slightest amount of ventilation would make my PS work properly.
So my question is:
Has anyone had experience similar to my problem here with possibly a faulty cap that is air tight?? Is the original cap vented ??
How does this problem get fixed?
Thanks guys,
Luke
So my question is:
Thanks guys,
Luke
