No Crank, Code B2101 in 2013 T&C @130k mi
Tags
b2101 nocrank
299 views 10 replies 2 participants last post by  Indi
#1 ·
I've read thru a few related threads here..issue still unresolved.
Sudden NoCrank, NoStart..only slight click near shifter. 3 FOBIKs (keys) recog'd, van battery charged, electronics working. Getting code B2101 (start signal low). Only issue that day: glitchy old FOBIK constantly locking van & tooting horn..retrieved new key to start & discovered NoCrank (MAYBE did something to WIM or TIPM??). Glitchy key hadn't created NoCrank issue before..just unexpected toots while driving or when nearby with key in pocket.
MAYBE related: Is Steady Red ETC light for 20secs at KeyOn normal? I've never seen ETC light while running..didn't notice it before at KeyOn since van always started right up with quick key turn (guess my great luck just ran out). COULD the ETC possibly trigger B2101 (start signal low) from WIM or TIPM as safety? ...EVEN w/no other codes (only new B2101)
History:
-I'm DIY techie-geek..MANY engine, electronics & accessory repairs.
-I've done a TON of reading & diagnosing last 4 days...some helpful ideas...LOTS of conflicting info & pointless, unintelligible AI videos.
-Have mid-range scanner w/live data, memory & reports
-3 mos ago replaced radiator for squirting leak on battery-side plastic..running fine since w/no issues or CEL. (No sign in TIPM..suprisingly 'new' inside when inspected below)
-Previous Code B2232B (Vehicle Configuration Mismatch) after setting a few other things with AlfoOBD w/OUT any starting/running issues...just hadn't gotten to resolving it.
-Phoenix summer heat...Started/Ran fine in 118F previous day..no crank happened early next morning @90F after using both DS doors & issue with glitchy old key constantly relocking van.
-Maybe some slightly rough idle for a while..just occas light 'stumble'...wasn't too concerning...no CEL or codes.
-Put new battery in FOBIKs (I tried all 3)
-Scanner shows keys recogn'd w/ good signal for accy, run & start.
-Tried NEW 12V Battery & cleaned cable connectors (tho old battery load tested OK)
-Car battery removed & swapped multiple times..no battery for 12hrs overnight..cables held together to drain capacitors...so multiple system resets.
-Key left in run position for 30 min w/connected battery charger (supposed to override some kind of lockout)
-Sadly, no Remote Start on Van..worked for some folks when key didn't
-Inspected wiring OK in DS Sliding door
-Inspected wiring OK in DS door.
-Checked & cleaned engine compartment GNDS I could find (2 on DS wheel well, 1 on top of trans, 1 near AirFilterBox)
-Brake switch works (brake lights illum & scanner shows switch working).
-NoCrank in park or neutral..scanner shows correct position. One slight click near shifter when turning key to start (won't click again until cycling brake pedal).
-Recalibrated accel pedal (could see output on scanner)...just in case it was related to ETC light at KeyOn
-TIPM removed, disassembled & cleaned inside. Only minor powdery residue on 3 large pins top board, PCBs & pins looked & smelled OK ('like new', no sign of radiator leak inside). Cleaned all pins & reassembled. Cleaned & tested all fuses good. Moved relays around.
-Didn't get far with WIM-TIPM test found on charm.li..instructions unclear or incomplete. I couldn't check signal @pin 30 on C7, car seems dead with C7 disconnected (FOBIKs do nothing, no lights, flashing SEC light). Can't reach wire or pin when connected..Red PWR cable to TIPM impedes TIPM being pulled out far enough.
SO, I'm wondering what to chase next????
I typ don't just start replacing parts w/out more info..but always willing to start with most likely, cheapest parts.
Local Dealers & Auto Electronics shops would have to order WIM or TIPM anyway...AND I like to know details about issues in my 'roadtrip' vehicle so I have a clue & a plan when traveling. I want to keep troubleshooting & learning.
MUCH Disassembly of Dash needed to get at $$$ WIM (YT video for less disassembly, but have BAD experiences w/ bending-twisting-breaking plastics brittle from AZ heat)
Can I 'force high' pin 30 @C7 on TIPM (start signal) w/out causing other damage? ..JUST to move van out of friend's driveway (Tech advised similar to resolve unrelated 02 Caravan ECU problem..worked miracles)
ANY other ideas welcome.
#2 ·
#3 ·
Thanks for the help.
Yes, its the 'lightning bolt' LED steady red for 20 secs at KeyOn then goes out with no related codes...maybe part of normal dash light KeyOn sequence, I just never noticed it before.
I've checked M27 many times..never blown..swapped with other 10A fuses..all contacts cleaned when TIPM was disassembled (though it looked 'like new' inside).
The link referenced above is what I referred to in my first post (wasn't allowed to post the full link as newbie). The confusing part is that with C7 disconnected from TIPM to test pin 30, the van seems dead..no lights, no response to FOBIK, turning start switch does nothing, pin 30 has no signal & not shorted to gnd...all seems kind of expected since removing C7 would disable the WIN.
Am I misinterpreting the test procedure?
#6 ·
VERY helpful to know about ThrottleBody..especially on long roadtrips. Thanks!
Its frustrating that NONE of the dealers in Phoenix could bother answering my simple question if ETC light being on for 20secs @ KeyRun is expected. Perhaps part the normal indicator sequence at KeyOn, but I've only had the van for 1 yr and it always started right up while I'm pulling seatbelt on, so I never noticed it before.
Now, just wish I could make sense of WIN vs TIPM diagnostics for code B2101. I've read thru both many times and have used similar diagnostics for issues in other cars. When I leave C7 disconnected to test pin 30 & reattached the lrg Red pwr cable to power TIPM, the van is dead (seems likely because that connector is for WIN needed to recognize the FOBIK & wake vehicle).
So there seems to be NO way to complete step 3 of 2nd section:
1. Turn the ignition off.
2. Disconnect the TIPM C7 harness connector. <===I disconnect pwr to TIPM to get at connector, then reattach pwr to TIPM before next step..can't sem to get enough length to leave it attached)
3. Turn the ignition on. <====THIS is where van seems dead, no lights..key not recog'd)
4. Measure the voltage of the (F20) Fused Ignition Run-Start Output circuit at the TIPM C7 harness connector. <===no +V on pin 30, not shorted to gnd)
Am I missing something?
Should I disconnect C7 WITH pwr to TIPM & key in but OFF (seems risky..always been in the habit of disconnecting pwr when messing with electronics, wiring & harnesses)?
Is van being dead with C7 disconnected when power reapplied maybe a clue to my issue??? (To me it seems likely behavior with nothing to recog the FOBIK & wake van)
I haven't found any live data point in my Scanner for Run-Start signal on pin 30 (Pnk/Wh sire)...is it maybe called something else??? (I'm inferring, not, or it likely would have just been part of the shop diagnostics)
#8 ·
I definitely appreciate the help. But I feel like I haven't been able to DO even 1/3 of the B2101 diag yet. As mentioned in step 3 above, there seems no way to Wake the vehicle or turn Ignition ON with harness connector C7 disconnected at TIPM. With C7 removed, how is the FOBIK authorized when I reattach battery?
I'm really not being stubborn...just have lots of experience with other electronics and computers...EXTRA careful not to damage anything else in what WAS a wonderfully performing vehicle...AND want to know for future troubleshooting since its my first encounter with both TIPM & WIN. They don't seem terribly robust or forgiving from the many posts I've read.
To maybe be more precise, here's what I've been doing attempting the steps above. I HAVE to remove lrg Red Cable on TIPM just to get the TIPM out of bracket, so I disconnect battery to be safe, then pull C7, then put TIPM back into bracket so I can reattach Lrg Red Cable (with C7 off to the side to test pin 30), then reattach battery. At that point, there seems no way to WAKE the vehicle...no lights, no indicators, no response to FOBIK..nothing.
Because the steps don't specifically say to disconnect power to TIPM before disconnecting C7..am I perhaps, somehow, SUPPOSED to pull C7 WHILE TIPM still has power & FOBIK has already been authorized & in the Off position? I've been inferring NOT given the short pwr cable & protective lug on TIPM. There's no way to free-up more length on lrg Red pwr cable without opening the harness it comes out of (I already pulled the plastic rivet attaching it to battery tray just to get enough slack to remove it from TIPM protective lug).
OR, are you saying because M27 is good (+12.6V at front blade with fuse removed, fuse tested then replaced)...and WIN seems dead w/C7 removed...THAT is indicating WIN failure? I see from the wiring diagram that WIN pwr comes out C6..not tested..but assume it's getting pwr because WIN authorizes my FOBIK to unlock car & recognize all 4 key positions when C7 is in place.
I really don't see HOW to do step 3 if FOBIK can't be authorized after battery is reconnected w/C7 removed...and feel like I haven't been able to complete even the first section of Diagnostic.
I TRULY appreciate patience in helping me understand what I'm missing.
#9 ·
You're not going to get the van to turn on like normal when that C7 connector is unplugged. If pin 30 has no voltage with the key turned or connection to ground, and there's no break in the wire between WIN and TIPM, the diag says the WIN is at fault.
#10 · (Edited)
Very helpful. Thanks!
Is the WIN really so delicate that it COULD be damaged by repeated lock signal from glitchy FOBIK? (maybe coincidental, but the only thing that happened just before NoCrank in an otherwise perfectly running vehicle..Same NoCrank after retrieving new non-glitchy FOBIK)
Is there ANY workaround for this condition if I'm on long roadtrip far from home? (like forcing C7 Pin 30 high either temporarily or from a fuse working at KeyOn) I miss the days when you could at least jump the starter to get back into civilization.
#11 ·
Soooo...turns out my ENTIRE mess was caused by remnants of KARR Security/Disable System tucked way up in dash (seemingly common by SoCal Dealers on Lease and Credit Risk vehicles, that previous owner knew nothing about). It was only discovered upon tearing apart entire dash to get at WIN (annoying design). Wad of melted & cut wires and gooey elec tape...relay cut into start-signal wire among tentacles of other wires, connectors & splices...had to do picture search to learn what it might be. It likely explains the weirdness of continuity & no short to gnd from connector-connector at KeyOff & 'floating' (no signal or short) when KeyOn..not really covered in diagnostics. I've never experienced a relay failing that way...somehow changing from NO to NC w/out rewiring ...perhaps an issue with melted wire mess...which, as mentioned in first post, coincidentally happened after driving & parking in 118F Phoenix temp previous day. It was a sticky nightmare removing it all from the vehicle..soldering some harness wires back together..got expected signals from diagnostics...Van started right up & runs fine. 7 frustrating days in the Phx summer heat at a friend's driveway solving this Dealer created mess. ARG!
BIG thanks for assistance here. THIS was a head-scratcher. But glad I now know to lookout for KARR in the future.
Now, if I JUST could figure out where these 3 leftover screws go. ;-)
