Polarity of auxillary 12V power outlet
1 reading
3.9K views 15 replies 8 participants last post by  Jeepman
#1 ·
Hi, I am going camping and I would like to charge my cell phone using a spare 12V battery, booster cables, and the cell phone charger that plugs into the ciggerette lighter/ auxillary power source.
I do not want to wreck my cell phone though by getting the polarity wrong.
So there are two electrical connections - the outer sheath, and the spring loaded plunger that is dead centre of the circular assemby. Does anyone know which is positive, and which is negative?
When answering could please indicate you degree of certainty. For example "I am 100% sure". or "I am 99% sure"
Thank you for your time
#3 ·
Positive in center and negative/ground on the outside is typical. Maybe not in England.
Think light bulbs. Do you have a multimeter? They come in handy, use one frequently for testing all sizes and types of batteries (1.5V, 6V, 9V, 12V, whatever).
Test light? finger in socket? :)
Reactions: atoman and Sienile
#7 ·
I think the OP put their finger in the socket and now is RIP. Sorry for giving that advice. 😔
#8 ·
Or just get a battery bank? I can't imagine lugging a lead acid up a mountain, or if you're near the van the battery should be capable of many phone charge cycles:
----Math---
Figure a car battery is probably 40-60 Amp/hours
~50Ah × 12v = 600watt/hours
Cellphone battery is roughly 3000-4000 mAh, or 3-4Ah, at 3.7 volts.
3.5Ah × 3.7v = ~13W/h
Most common smartphone charger is 2.4amp at 5 - 5.2volts.
2.4A × 5.1v = 12.25watts
600W/h ÷ 13W/h = 46
Your car battery holds roughly 46 times the energy of a phone battery
600W/h ÷ 12.25W = 49 hours
Your battery could run a phone charger(charging a fully dead phone) for ~50 hours.
Reactions: Jeepman
#13 ·
"Deep cycling" a car battery will cause it to degrade quickly and fail prematurely...
"Group 34 batteries are medium-large, but still rather powerful batteries, featuring 20h capacity in the 50-75 Ah range"
Automotive wet Pb battery cycle is designed at ~20% (beyond that the plates start irreversible degradation), so regularly pulling over ~15Ah from your car battery will lead to capacity loss and a need to replace the battery.
#9 ·
WOW! A firefighter that's good at math too. :)
I like those calculations. (y)
Reactions: Special Edy
#10 ·
Don't most modern chargers auto-switch polarity anyway? I know AC chargers do this (especially in US).
I agree with Edy that a purpose-built power bank is a much better alternative for a "portable" device. If you had a static assembly being used for solar or something, then maybe PbAcid is a cost effective option. But for just a cellphone, get a large battery bank, and if it's in the budget, get one with an AC output, if needed. Lots of those available in the $125US/£100 range.
Otherwise, steer clear of lead-acid unless you're prepared to really build a stable/safe enclosure. Li-Ion is here now (see "Jackery"), but LiPo is the way of the future...and better for temperature swings found outdoors in camping environments.
#11 ·
I don't know of any 12v accessory that switches polarity aside from the devices to check if they are operating. USB C chargers will switch on the output side only.
#16 ·
Yep, Cottage Country McDonalds. Sour dough bread and rabbits. Lumberjack burgers, axe included. :)
