Power Steering (What fluid?)
1.4K views 12 replies 6 participants last post by  Matt182021
#1 ·
I've seen a few different opinions on this across different threads, but they are are a bit old, figured I'd start a new one. What fluid should I use in my power steering system? 07 TC Touring.
I've always used regular power steering fluid, but from what I've read, that may have been a baaaad thing. Hope I haven't caused any irepairable damage to my factory steering system! 😬😬
#4 ·
It takes ATF+4. Same fluid as the transmission.
How much SP fluid did you use? Just a top off or have you worked on it?
I don't know if the system is heavily dependent on the +4 or if they say that just to keep things simple with the fluids.
#5 ·
ATF+4 fluid. It was changed to that since the 3rd generation vans started having some issues with shudder, so there was a TSB issued to change it to ATF+4 back then. In the 4th gen, they just opted to use it right off the bat to head off any issues. It has excellent anti-shear properties which was why they switched to it.
When I first got our 3rd gen van back in 2009 and had to replace the power steering pump, I immediately cleaned out the remote reservoir and switched it over to ATF+4. Never had any issues in the 50,000 miles we've driven it since, and I refilled it with that when I replaced the steering rack and lines with junkyard replacements (due to heavy corrosion/rusted through line). Even the replacement steering rack I got had ATF+4 in it!
#8 ·
What, you don't want to raise the van,crawl under it, take the hose off the rack and let it spray everywhere, even on you!
:LOL:
owns 2006 DODGE GRAND CARAVAN SXE
#9 ·
After many a power steering fluid flush with a darn mighty vac brake bleeder (would have to empty the bleeder 2.5 times for one reservoir emptying 😑) I made this nifty little setup, makes my life SOOO much easier.
Ain't pretty, but it will empty the PS reservoir in about 3 seconds!
#10 ·
Ah ha, so this is how one makes FAKE moonshine. :ROFLMAO:
