Thanks Doug. Looking at that chart for a few minutes, I wonder if the underdrive clutch is applying all the time. Does 4th gear work fine or does it drag in 4th too?
"The Solenoid/Pressure Switch Assembly (Fig. 317)
is external to the transaxle and mounted to the
transaxle case. The assembly consists of four solenoids
that control hydraulic pressure to the LR/CC,
2/4, OD, and UD friction elements. The reverse
clutch is controlled by line pressure from the manual
valve in the valve body. The solenoids are contained
within the Solenoid/Pressure Switch Assembly, and
can only be serviced by replacing the assembly.
The solenoid assembly also contains pressure
switches that monitor and send hydraulic circuit
information to the TCM. Likewise, the pressure
switches can only be service by replacing the assembly.
The solenoids receive electrical power from the
Transmission Control Relay through a single wire.
The TCM energizes or operates the solenoids individually
by grounding the return wire of the solenoid
needed. When a solenoid is energized, the solenoid
valve shifts, and a fluid passage is opened or closed
(vented or applied), depending on its default operat-
ing state. The result is an apply or release of a frictional
element.
The 2/4 and UD solenoids are normally applied,
which by design allow fluid to pass through in their
relaxed or “off” state. This allows transaxle limp-in
(P,R,N,2) in the event of an electrical failure.
PRESSURE SWITCHES
The TCM relies on three pressure switches to monitor
fluid pressure in the L/R, 2/4, and OD hydraulic
circuits. The primary purpose of these switches is to
help the TCM detect when clutch circuit hydraulic
failures occur. The range for the pressure switch closing
and opening points is 11-23 psi. Typically the
switch opening point will be approximately one psi
lower than the closing point. For example, a switch
may close at 18 psi and open at 17 psi. The switches
are continuously monitored by the TCM for the correct
states (open or closed) in each gear as shown in
the following chart:
PRESSURE SWITCH STATES
GEAR L/R 2/4 OD
R OP OP OP
P/N CL OP OP
1st CL OP OP
2nd OP CL OP
D OP OP CL
OD OP CL CL
(OP = OPEN; CL = CLOSED)"
And Underdrive clutch application would trip a pressure switch in the solenoid pack and set a code, most likely. And the OP put in a new solenoid pack..So if the Underdrive clutch is being applied, it's a mechanical fault not a control fault and not being detected by the TCM.
