I own two Voyagers, a 1988 LE and a 1994 LE. the old '88 was plagued with little issues I've had to fix over the last couple of years. The engine and Trans work fine, its all the other nickel and dime stuff I've had to sink into it that's been killing me. So far, rebuilt front end, 3 ball joints, 2 tie rods, 1 bearing unit and two complete struts I've put in myself. New fuel filter, (original one never replaced in 25 years!), new 02 sensor, new plugs, wires, distributor cap, several oil changes, air filter, new rims, tires, lift gate shocks, solder repair of wires leading to driver's door for power locks, new shocks in the back, front driver's caliper replaced (my fault, i screwed it up after stealing the rotor to put in the '94 in a pinch), to the auto wreckers for a replacement grill to replace the one I accidentally broke, a front wiper motor that had ceased up after sitting and a better headlight. Now i need to hit the auto wrecker for a set of rear drums and pads as we are now metal on metal. Also, the Rack and Pinion is leaking bad and will need replacement. This is my winter beater, looks rough but will eat the ice, sand and salt while the '94 sits in the garage for the winter. They are both work Vans and have both paid for themselves several times over and cheap like borscht to insure.
The 1994 on the other hand is a far superior vehicle, engineered from the ground up, not something whipped together and thrown on a K car platform like the Gen 1's were. This Van is by far the most reliable vehicle I've ever owned and has only needed minor repair. So far, it has needed a new starter (i burned the old one out), an EGR valve, front brake pads and a rotor stolen from the '88, the van didn't start from the ignition so I had to jimmy rig a push button starter system in, new plugs and wires, a transmission fluid change I did myself (stick to ATF + 4 folks, I recommend Mobil brand) and a rear gate wiper motor, new tires and rims (went back to stock steel ones, the aluminum bling bling rims that came with it were bent beyond repair, and a few oil changes. I purchased it a year ago for $540 form a soccer mom who just bought a new vehicle at the time and was desperate to get rid of it in a truck heavy used vehicle market.
I've owned a couple of 1995 Vans before, a Caravan and a Voyager both with the A 604 four speed nightmare transmission and both vehicles packed it in and were junked. I've also owned a 1986 Caravan with a 2.2 four cylinder and a stick, a 1987 Mini Ram and a 1988 Grand voyager. I have owned trucks but I still to this day prefer Minivans for their versatility, comfort and roominess.
I will send pics later. Thanks!
