I had great results with a 2.6l Mits. in my new Aries K 1981. Drove it 225k miles without any trouble over 11 years. I did the routine maintenance as required religiously and it was great. The weak points were the fuel pumps, one every 40k miles (buy a lifetime one, free after the first). I adjusted the three valves every 15k as directed. Also the camshaft seal leaks at the drivers end after about 50k/seal. You can drive it in with a socket. The Mikuni carb I had lost the choke (hot wax type) after about 70k. I just cut a piece of a tin can, drilled a hole in it to fit on a screw nearby and bent it so the choke plate was permanently 1/8" or so open. You had to pump once in summer, twice in winter and it would crank right up without the expensive choke unit. That is it. The cable on the transmission to the stick is a little light, broke 2, but Started putting it in N, placing brake on, then letting weight of car rest on brake, then shift into P and never any more problems. Hope he enjoys his. Any time you have a question, feel free to ask. There is a little canister on the firewall of that carb, the CAV, coasting air valve. If it sticks open, it will start fine and run fine over 1200 rpm, but when it warms up, you will hear a weird sucking noise and it will stall when you come to a stop. disassemble the canister, put some silicone on the tip of the needle, and you are good to go. Took me a year to find it since it was sporadic.
