What does the psi number on the tire placard or label have to do with tire safety? What are the risks of underinflating or overinflating?
The psi, or pounds per square inch, number on your tire placard or label represents the pressure you should fill your vehicle’s tires with to ensure tire safety. Under- and overinflating tires can both be safety hazards. Overinflating tires can adversely affect vehicle maneuverability, make the ride harsher, and sometimes lead to loss of control and crashes. Underinflating tires – a potentially more serious problem – can result in tire stress due to overheating, irregular wear of tread, tire failure, and sometimes loss of driver control and crashes. So obviously you’ll want to know the correct psi for your vehicle, check your tire pressure at least once a month with a tire gauge, and adjust tire pressure accordingly.
