2001 T&C LX w/Infinity System, missing rear speakers - need to replace
7.4K views 13 replies 4 participants last post by  douggro
#1 ·
Greetings! I recently bought a 2001 Chrysler Town & Country LX, and found that the rear speakers are missing entirely from this vehicle. There don't seem to be any tweeters in the rear (there's a black covered styrofoamish substance under the little round grilles) and only one wire harness inside the panel, with a 6-pin connector. I am assuming I have the Infinity system as I have only found pictures of that connector on amplified 6x9 speakers with the part # 04685855AF, which are def. Infinity system speakers.
Looking at the connector, I have not been able to find any matching speakers for sale that aren't an exorbitant price, so I was wondering if I could splice in a pair of 2-ohm or 4-ohm, 3-way speakers to that wiring, which wires I'd need for that out of that bundle, and how bad would that sound off the factory head unit, with the OEM speakers up front?
Anyone who can toss me a wiring diagram for that connector or tell me what=what?
Also, if this has a separate +/- feed for the tweeter (4 wires for sound and 2 for 12v for the amp I won't have), would I pigtail the two + together (and the same for the -) and connect the pigtails to the +/- terminals of a 3-way speaker, or simply splice into the main "woofer" set to get full range and full output power?
Thanks a million!
#2 ·
#3 ·
Got it Doug, thanks!
To add to my earlier open questions, I was looking at likely replacement speakers and was thinking about these: JBL GTO938 6x9 Speakers (pair)
They're 2-ohm impedance, relatively high RMS/Max Wattage values, any thoughts on how they'd sound (subjectively, of course)? I tend to run my stereos about 40% front/60% rear usually to take advantage of the empty space and not have it so "in my face" - what's the consensus on mixing coax with component speakers in this fashion?
#4 ·
The factory connector for the rear speaker has the following pin-outs, looking at the open side of the connector with the locking tab at the top:
3-2-1
6-5-4
1: (20)DG/WT Pillar Speaker -
2: (16)GY/DG Amplified Speaker Ground
3: (20)DG Pillar Speaker +
4: (20)DG/DB Rear Speaker +
5: (16)DG/GY Radio Choke Output
6: (20)DG/OR Rear Speaker -
IIRC, the Inifinty system uses amps located on the speakers. The front door and rear main speakers have the amps, and the dash and pillar speakers are fed from those connection points as those speakers use only a two-wire connector. As such, I imagine the pillar and dash speakers are getting any amp power from the amp output at the main speaker they are connected to. The head unit has a single connector for triggering the amp relay in the IPM which then supplies the power to the speaker amps.
#5 ·
Thanks for the confirmation on the wire colors and pinout, that helped me a lot. Last night I tested a seemingly decent pair of BOSS speakers I had from my previous car and they sounded like garbage, and quiet as ****. So I'm back to trying to find OEM replacements with the integral amp.
I found a pair of Chrysler Infinity 4685610A speakers (onboard amp, 35w RMS, integral coaxial tweeter, 4 pin connector) - would these do? I'd still have to cut the factory connector off and splice, but wires 2,4,5 & 6 would be connected and leave 1 & 3 unconnected, I assume.
#12 ·
So I got the speakers, wired up the left one and tested with the stereo set to left rear... And got nothing. This is starting to be more trouble than it's worth... Do I need to wire up both sides to get any rear output (in other words did it need to be drawing power on both sides to activate one side's amp at all?)
#14 ·
Check for voltage across pins 2 (amp ground) and 5 (+ radio choke output). Those should be powering the built-in amp, ~12V. You should also see voltage of some kind across the +/- signal wires. If the front speakers are Infinity's and are working, the amp relay is working. Or try hooking them to the door speaker connection - they appear to use the same connector and the wiring matches.
