21 - 40 of 67 Posts
The common fix, surprisingly only mentioned in passing unless it's in a link, is to replace the gas tank. Don't recall the name but there is a valve built into the top of the tank that if not sealed as the fuel level rises will allow gas to flow to the charcoal canister. If the valve is working you can top off as much as you like. If not, you'll have problems. I regularly top of my 20 year old 96. No problems yet.
I've often wondered if installing and replumbing the canister above the level of the gas tank might be an alternative for some. I've never read of anyone trying it.
Is there an underbody area that's above the gas tank that wouldn't be up in the passenger/cargo area? I have seen the cannisters on other vehicles (with a lot more plumbing) mounted under the hood, perhaps a little higher in elevation than the gas tank.
Above the fuel tank. Makes me think K.I.S.S.
Has anyone put a liquid separator in line between the charcoal canister and the tank or put the charcoal above the tank to make it drain back in?
I've never lowered my fuel tank or had a reason to, but (and maybe this is just because mine is a Stow n Go) I have a hard time believing that there's more than about a thin pancake's worth of space between fuel tank and floor...am I crazy?
Nah just smarter than Chrysler
Keep it simple <strike>stupid</strike>Chrysler.
Has anything happened in the investigation mentioned in the OP? Our van has gotten worse and worse with this problem. I didn't bother to come back and mention it because we'll just get the same response as last time: "stop when it clicks off". That advice is useless because that is what we have done ever since we got this van. Now, ,even sitting a few minutes and revving the engine does not work any more to prevent this.
As I stated "above THE LEVEL of the gas tank". Doesn't mean above the gas tank itself. It would have to go in the engine compartment.
So if I'm interpreting this correctly, you're suggesting to those that have the problem that it might work if they consider half a tank or so "full" and do not fill beyond that point? That would leave the level of the gasoline (liquid) in the tank below the level of the charcoal cannister and then there should be no problems with liquid overflowing into the cannister for the simple price of more frequent fuel stops?
Sounds at least cheaper than replacing the gas tank.
Nate
i also have this problem. 2005 caravan 3.3l.
everytime i fuel, 10$ or 80$, it bucks/almost stalls if i get on the highway and it stalls if i go on a small street with low throttle.
i read a lot and its the roll-over valve on top of the tank. its plastic welded into the tank and is not replacable.
i read that blocking the hose that leads to the charcoal canister will fix the problem but it will turn on the check engine light.
Discussion starter · #29 ·
I haven't heard anything else about this.
What I suggest right now is to report this issue to NHTSA ASAP and possibly reference this thread just to push them to do a recall, as this is a safety issue...
Discussion starter · #30 ·
In recent days the van hasn't stalled after I filled up on gas (fill until click). What I have noticed during the last 2 fillups is that as soon as I drive off, the van bucks badly for a few seconds sending the RPMs everywhere...it does that for a few seconds then stops.
I filled 70 liters at a different gas station today and had no issues...I will continuously watch this...
Change the tank.... It's the only fix. Mine got to the point where moisture in the canister froze and wouldn't allow me to fill the tank until it thawed. When it did I disconnected the line that ran to the canister from the tank and raw fuel just poured out f a line designed for vapor, so this is a serious safety concern that should be taken seriously. If your a do it yourself, you can find new tanks online for between four and six hundred dollars and install it yourself. Change the filler tube and canister while your at it for piece of mind! Keep your receipt in the event chrysler decides to extend the guaranty like they did for the same problem with the charger and the 300
Chuck
Discussion starter · #33 ·
My 2005 did today after fill up and did not top off. A little embarrassing when it dies in the middle of the road. I have noticed it will stalls when it's warm outside and won't do it all winter long.
Now that it's warm out the van has stopped doing this, but in the winter it would do this nearly every fill up...Unfortunately, nothing will be done about this issue now...
My 2004 Limited has done this since I bought it used three years ago. I'm used to it now but very leery of letting anyone else in my family drive it. Usually after I fill up I just go into the station and take a short break, buy a coffee or soda, and the gas effects are less. Now I thought about replacing the tank, $300 to $400, but I have 155k on the van now so I know that fuel pump should be replaced too, $500 to $600 more if I do it myself while the tank is off. So this little problem would cost me over a $1k to fix if I did it myself. I think I'll just stick with the coffee and soda for now.
I'm curious; where are you seeing prices of $500 to $600 for a fuel pump for a 2004 T&C Limited? Here in New Hampshire the price of a new fuel pump ranges between $120 and $160.
This post gave me an idea. My car will not start. Happened out of the blue. It had been sitting a while. Batt was charged up. Before I started it, I added gas from two 5 gal. gas cans. Filled it all the way up. If I overfilled it, would this cause a no start? It has never not started before. Won't even turn over? Just a relay click. Gas gauge has been "odd" ever since I bought it. Gauge when it wants to.
21 - 40 of 67 Posts
