If there is coolant in there, yes, it would be wise.When changing out the old plastic housing for the new Aluminum one:
I have read that you should drain some of the engine coolant to lower the coolant level below the oil cooler housing position, to avoid having coolant flood into the oil passages when the filter housing/cooler block is removed.
Is that correct?
Any need to also drain off the engine oil levels for the same reason?
Make sure you also get the 2014+ cooler block, filter cap, and filter. Those parts will not swap from a 2011-2013. Your sensors can be moved to the metal one without issue.Ooh, fancy! I have been comtemplating upgrading the oil filter housing on mine to the 2014+ part, I guess my mind is made up now.
Routing is: US source to Memphis, to Montreal, to Dartmouth NS, and out for delivery. About 3 to 4 days once the item is picked up to start the process.Why does my FedEx package go to Memphis?
It is the busiest cargo airport in the United States, second busiest in the world. Many of the packages go through Memphis because they have the technology/manpower to sort packages there to determine where they go. FedEx has easy access to most of the country with the central location of Memphis TN.
Do tell....My daughter found a little trick to have her Amazon packages delivered on the same day she order it. I tried it and it really works if you live in a major city, otherwise you get it day after. No additional fees either.
