Sorry, I think I made I mistake. Not the seals were supposedly not well machined but the seal holes on the housing weren't well machined. Or something. I don't remember anymore. I mean every Dorman housing that I've seen has been the same from the pictures I've seen. If the part was designed, tested and manufactured the way it is with the seals that are provided with it then that's the way it is and that's the way it should've been installed in the first place.Dorman fit and finish suffers somewhat, in my experience.
What kind of seals were they, cheap cork/paper gasket, silicone coated, or something crushy.
AeroZ is the only one I've heard had issues, but it seems like it might be a screw up by his mechanic.So is this Dorman part a good quality one or is it a poor quality replacement part?
Yeah, I’m pretty sure the mechanic screwed up and the part is fine.AeroZ is the only one I've heard had issues, but it seems like it might be a screw up by his mechanic.
It's pretty hard to screw up a solid piece of metal. That's all the Dorman part is, a metal adapter and the gaskets to install it with.
The old manifold gaskets were all pretty flat, and looked like there was oil seepage, so yes I would recommend changing them out.PS. Do you have to replace the intake manifolds' gaskets every time you remove them or just when the installed gaskets are old and worn?
Thanks. With the second method how do I know that enough coolant has been drained?Loosen the cap for the oil. For the coolant, if you remove the thermostat the coolant will drain below the cooler so you avoid a bigger puddle in the valley. Opening the radiator drain and the thermostat bleeder screw at the same time is probably an easier way and makes less mess.
Yep, just the next version of the assembly. It changed how the filter bypass worked. It went from the center tower for the relief valve to the cap.
AeroZ posted a few back that Dorman will be selling a 1-size-fits-all complete assembly (926-959) within the next few months. Initial retail is set at about $370. It's just going to be this version with all the parts you'd need for the '11-'13 conversion already on it. Think I heard someone mumbling about June 6 for the launch and next shipment of the bare units.
Alright! It's out. Good to know.
The Dorman’s installation manual only has the torque specs for the cooler to housing. Since the OEM part comes with preinstalled cooler you won’t find those torque specs from a service manual.The directions that come with the Dorman housing also include the torque specs. The important one will be for the cooler to housing seal which is not in the posted specs if I recall correctly.
Those torque specs are the same from 2011-2020 and likely the same on all other 3.6 engines.Hi Everyone,
New member here.
I'd like to know if the engine torque specs that were posted by Sienile back in post #137 apply to a 2016 Dodge Caravan.
Thanks to all of you for your time and sharing of your information/experiences!
